Small squeal upon acceleration.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MGH-PA, Oct 27, 2009.
  1. Oct 27, 2009 at 6:15 AM
    MGH-PA
    MGH-PA [OP] Well-Known Member
    Northcentral, PA
    05 Tacoma TRD AC 4x4
    265/75/16 Nitto Terra Grapplers, Bestop
    Ok, so I recently switched out my serpentine belt (82K miles) because it was squealing regularly. Problem fixed. Fast forward to a few weeks later, and I'm starting to get a subtle squeak under the hood (sounds like it could be more towards the driver's side) when accelerating. It's usually more prominent during warm up, but it definitely only happens when accelerating. If I let off the pedal, it stops. Any ideas? Not sure if it's a pulley, bearing, or what? I haven't had the chance to get someone to sit in the truck and accelerate for me while I listen.
  2. Oct 27, 2009 at 6:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    It sounds like a pulley to me.
  3. Oct 27, 2009 at 6:21 AM
    AZFizik
    AZFizik Slowpokeologist
    James
    Phoenix
    07 TRD OffRoad Prerunner
    TRD Catback & CAI, Fogs only, Recovered Armrests, BFG AT's
    How long ago did you put that belt in, and did you have greasy hands when you did? If so, try spraying the belt (when cold) with some brake cleaner, that'll take off any oils that might still be there.
    Could also be a bearing going out on the alternator, but thats much less likely.
  4. Oct 27, 2009 at 6:28 AM
    MGH-PA
    Northcentral, PA
    Nope, no grease, but I'll try spraying it down to see what happens. In the meantime, any other ideas?
  5. Oct 27, 2009 at 6:50 AM
    AZFizik
    James
    Phoenix
    I think a greasy belt and a bad bearing on an accessory throwing a bearing are about the only things that are gonna cause a squeak like that. You don't have a 6spd so the TO bearing problem isn't one for you.
    You're sure this isn't brake squeak you're hearing right?
  6. Oct 27, 2009 at 7:12 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Tensioner not tight enough? Can you push the belt lightly and it flexes? You shouldn't have too much flex when you push it... it should be be quite tight.
  7. Oct 27, 2009 at 7:18 AM
    MGH-PA
    Northcentral, PA
    Yep, definitely not the brakes.
    Briangp, I'll check the tension this afternoon.
  8. Nov 8, 2009 at 3:38 PM
    MGH-PA
    Northcentral, PA
    Just getting around to finally checking this. No grease on the belt from what I can see. How much should the belt flex? I can press on it, and it flexes inward a little ways, but it's still pretty tight. The squeal is pretty regular now, and usually lasts for the first 5-10 minutes after cold starts.
  9. Dec 9, 2009 at 7:19 PM
    eyball
    eyball Well-Known Member
    Dudley, MA
    20 Double cab TRD Sport Voodoo Blue
    Did you figure this one out yet? I am still dealing with this problem. I replaced all 3 idler pulleys and tensioner pulley as well as a new Dayco belt and still had noise. I am back to my Toyota belt the dealer installed last March and noise is temporarily gone but I am sure will be back in days or less.
    So at this point I am thinking Alternator or maybe the power steering pump? there is nothing else except AC, water pump, & crank shaft.
    Could pulleys be out of alignment?
  10. Dec 9, 2009 at 7:21 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    could be too much power :confused:
