SMALL VIBRATION HELP PLEASE
Discussion in 'Suspension' started by dgreene, Jan 26, 2011.
  1. Jan 26, 2011 at 3:41 PM
    dgreene
    dgreene [OP] Well-Known Member
    GA
    2011 DC TRD Sport 4x4
    3in toyotec with eibach coils and 5100. nfab side bars,procomp 7032 wheels with 275/65/18 nitto TG,low profile tool box,tint, borla exhaust
    Got 1.5 aal and 3/4 spacer put on top of my 5100's today have not got front end aligned yet thats tomorrow but have a small vibration going through 25 up and down any suggestins or should the alignment take care of that i hope. Thanks
  2. Jan 26, 2011 at 3:45 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Why did you put a 3/4 spacer on top of the 5100's? And what do you have them set at. The 5100's are not really designed to be used with spacers.
  3. Jan 26, 2011 at 3:49 PM
    BryWi
    BryWi Psalm 109:8
    Earth
    2011 TRD off-road DC SB w/JBL
    5100s, black valance
    I've got 5100s (4) and the TSB and I have a slight rumble/vibration from 22-27 MPH on deceleration ONLY. I had the alignment done.
    I know the situation is a little different, but the fact that your vibe is around 25 is a little curious.
    I would think the vibration issue would be evident at other MPHs, not just 25.
    Please post any info you get...
  4. Jan 26, 2011 at 4:12 PM
    dgreene
    GA
    Its the one that comes with the kit from toyotec it gives you the options for the spacers. It on there website with the 5100 and eibach kit as an option.
  5. Jan 26, 2011 at 4:13 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    My low speed vib was fixed with a carrier bearing drop. Try that.
  6. Jan 26, 2011 at 4:29 PM
    dgreene
    GA
    Did the alignment take care of it. Thanks
  7. Jan 26, 2011 at 4:37 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Where is the vibe coming from?
    I'd go get it aligned and see if it goes away.
    Any rear lift?
  8. Jan 26, 2011 at 4:38 PM
    08pretaco
    Oliver
    az
    see the OP it has a 1.5" AAL
  9. Jan 26, 2011 at 4:42 PM
    TacoNut
    Adam
    Denver, Co
    Ahh I see....
    Reading is hard, sorry :p
    If it's coming from the rear OP can try a carrier bearing drop, or 1 pc DS.
    Although with 1.5" your driveline angles shouldn't be too extreme.
  10. Jan 27, 2011 at 9:49 AM
    BryWi
    BryWi Psalm 109:8
    Earth
    Nope. That was AFTER the alignment. I didn't drive it before.
