Smaller pulley and aFE intake require A/F gauge.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nof555, Aug 24, 2015.
  1. Aug 24, 2015 at 2:14 PM
    nof555
    nof555 [OP] Well-Known Member
    VA
    Black S/C 2015 Sport
    Work in progress
    I am curious if anyone has ran the 2.85 stealth pulley and aFe intake on a trd supercharged 4.0 and ended up lean. It would seem everyone claims the TRD tune is rich no matter what. Had anyone heard of running lean after those two mods. I don't have the upgraded fuel pump but I only have 1,500 miles on my truck, so I'm not too worried about the fuel filter getting clogged yet.
  2. Aug 24, 2015 at 5:59 PM
    nof555
    VA
    Work in progress
    Anyone?
  3. Aug 24, 2015 at 6:45 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I dont have a pulley yet, but after i installed that very intake i noticed my AFRs spent more time being rich then they ever had before. Dont really know or understand why. Just my experience.
  4. Aug 24, 2015 at 7:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup. smaller pully n CAI to support it.... throw a better fuel pump in, you need it regardless.
    Torspd likes this.
  5. Aug 25, 2015 at 6:16 AM
    nof555
    VA
    Work in progress
    I understand this, my question if anyone has had any issues with the air/fuel ratios being too lean. In other words, I'm looking at running both of those parts with my supercharger as well as my cat back exhaust. As long as no one has come close to running lean with those mods, I'm not going to bother getting a wideband O2 sensor.
  6. Aug 25, 2015 at 10:42 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    I have yet to install everything but......... I plan to run the TRD Blower with the 2.85" pulley and TRD Gen1 intake. I also have the fuel pump upgrade, DT Shorty headers, custom exhaust, etc.
    I don't plan to install an A/F ratio meter. I plan to put in all the parts that I'm accumulating for the blower install, break it in and get it strapped on a dyno. The A/F chart from the dyno run should determine if the TRD ecu reflash is closer to stoich. If it's still "rich", I have a EcoBlock MAF spacer that I can throw on and dyno for shit-n-giggles and see if it leans out the tune and by how much. If the tune is running rich/lean, I have a URD MAF Cal to play with and the knowledge/experience of fellow TW member @Vassily28 (MAF Cal wizard) for me to pick his brain.
    I expect what the Lobster said to hold true. My future dyno run should confirm or refute that.
  7. Aug 25, 2015 at 11:14 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    I had a similar set up, 1st gen TRD CAI + ProDry, TRD Catback, 2.85 pulley, and Doug Thorley LT headers, TRD reflash + MAF cali.
    Then i change my Y-pipe and take the occasion to do 3 logs.
    1- Before Y-pipe
    2- After Y-pipe
    3-After Y-pipe and fuel pump upgrade.
    The 3 runs were with the same map. The result shows that before the Y-pipe i was at the limit of the fuel pump. Take note that i had the OEM FPR mod. I've done the proof of the benefits of the OEM FPR mod on the AFR in an other thread.
    I highly recomand the installation of an AFR gauge. Without it, it's at your own risks.
    Torspd likes this.
  8. Aug 25, 2015 at 11:16 AM
    Vassily28
    OEM FPR mod impact.
  9. Aug 25, 2015 at 11:47 AM
    nof555
    VA
    Work in progress
    Let me know your results of it if you don't mind.
    SUMOTNK[QUOTED] likes this.
  10. Sep 6, 2015 at 9:29 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    @XeddeX anything?
    nof555[QUOTED][OP] likes this.
  11. Sep 6, 2015 at 11:28 PM
    SUMOTNK
    Eddie
    Not yet... I've been lagging on the blower install. Been occupied with some suspension mods.
    I'll update this thread when I've completed my said tasks.
    nof555[OP] likes this.
