Smallest wheel spacer to clear 285s?
Discussion in 'Wheels & Tires' started by 04SwampTacoma, Mar 18, 2015.
  1. Mar 18, 2015 at 3:39 PM
    04SwampTacoma
    04SwampTacoma [OP] Member
    Ville Platte Louisiana
    04 4x4 SR5
    2 inch Readylift leveling kit, Winjet Tail lights,
    Im new to Tacoma World and I've done some searching with no luck. I have an 04 Tacoma 4x4 with a 2 inch spacer lift. Im currently running 265/75/16s with 16x8 wheels and 4.5 back spacing. Im thinking about stepping up to a 285/75/16 and i know ill need wheel spacers. Whats the smallest spacer i can go with to minimize the rubbing?
  2. Mar 18, 2015 at 3:42 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    with 16x8 4.5 backspacing rims, you should NOT need additional wheel spacers.
    That's only when running 285 width tires on factory rims.
  3. Mar 18, 2015 at 4:34 PM
    04SwampTacoma
    04 4x4 SR5
    So will I be able to run 285s with out any rubbing? Or will there still be some trimming needed to be done? I already have my mud flaps removed so that wont be an issue.
  4. Mar 18, 2015 at 5:32 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I didn't say you wouldn't rub. :D
    Most folks find they have to trim wheelwell plastic.
    Some folks, especially four-wheeling, need to do the cab-mount chop.
    But adding wheel spacers wouldn't help with any of that, and would actually make the problem worse. Wheel spacers keep the tire from rubbing on the upper control arm. Typically, a need for a wheel spacer is revealed when you can't even mount the wheel on the truck.
  5. Mar 18, 2015 at 5:54 PM
    04SwampTacoma
    04 4x4 SR5
    Well i dont plan on doing any four wheeling and a little plastic trimming never hurt anybody. Thanks for the input man!
  6. Mar 19, 2015 at 5:29 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I found that at full lock even the slightest compression of the suspension would cause the tires to rub on the frame a bit, a set of 3/4" spacers from Bora cleared that up.
  7. Mar 19, 2015 at 5:34 AM
    Texas50
    Texas50 Well-Known Member
    Brazoria County-Texas
    11 TRD Sport.
    OME 885's,Light Racing UCA's,Bilstein 5100's all the way around, Deaver AAL. Cooper 265/70/17
    I had 285/70's on stock sport wheels with 1" spacers and rubbed all over the place. Driving the truck straight was no issue. Turning, even slightly, and hitting any bump in the road I rubbed. Backing out of the driveway and turning I rubbed. Backing straight and hitting a bump, I rubbed. I took off the spacers and went to a 265/70. Truck does not look as nice but zero issues...
  8. Mar 19, 2015 at 1:39 PM
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    Running 285/75/16 MT on stock trd offroad wheels with 1.25 wheel spacer. At full lock it rub a bit of plastic and just a bit of the cab mount. Knife to the plastic was easy. For the cab mount. I just shave about half way and problem solve. Paint it black and good to go. No rubbing on full lock when hitting bump on or offroad.
  9. Mar 19, 2015 at 2:07 PM
    04SwampTacoma
    04 4x4 SR5
    The wheels im running having 4.5 back spacing.
