Smart Entry & Start System Check Error
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jcmartin11b, Jun 7, 2020.
  1. Jun 7, 2020 at 5:29 PM
    Jcmartin11b
    Jcmartin11b [OP] Well-Known Member
    Justin
    Los alamos,NM
    22 Tundra Trd Pro
    So I get this pop up on the dash 50% of the time. Truck still starts and unlocks fine. Any ideas?
    nothing was installed around the time this started. I do have a remote start installed but that was done a month before this issue started
  2. Jun 7, 2020 at 7:39 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Have you tried changing the fob battery/ using the 2nd fob? The receivers (there are 2) also seem to very temperamental to voltage changes so have you added any electronic accessory’s recently?
    Jcmartin11b[OP] likes this.
  3. Jun 7, 2020 at 7:39 PM
    Jcmartin11b
    Justin
    Los alamos,NM
    22 Tundra Trd Pro
    Used both fobs and also did change the battery in the one I use all the time.
  4. Jun 7, 2020 at 7:40 PM
    Jcmartin11b
    Justin
    Los alamos,NM
    22 Tundra Trd Pro
    Have added a new radio (head unit). Probably the most near term addition. With a dash cam
  5. Jun 7, 2020 at 7:52 PM
    mutely
    what kinda headunit? If name brands then I’m sure it’s not the problem, if it’s one of the Android tablet type units then “personally” I’d unplug the power and see if that’s interfering with it.
  6. Jun 7, 2020 at 8:04 PM
    Jcmartin11b
    Justin
    Los alamos,NM
    22 Tundra Trd Pro
    Kenwood with their dash cam that works with it
  7. Jun 7, 2020 at 8:31 PM
    mutely
    them I’m kinda at a loss. When I was having issues with keyless entry I found an excellent online pdf (from Toyota) that explained how the system worked, where all the components where and all the different checks you can do. I can’t find it now, But it may be worth searching for it.
  8. Jun 7, 2020 at 8:48 PM
    Jcmartin11b
    Justin
    Los alamos,NM
    22 Tundra Trd Pro
    Will look for it. Thank you!
  9. Jun 7, 2020 at 8:50 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  10. Jun 7, 2020 at 9:00 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    http://www.ttguide.net/system_description-1769.html
    Situation: The smart key system is malfunctioning. An IG circuit malfunction, vehicle speed signal malfunction or malfunction that interferes with steering lock ECU (steering lock actuator or UPR bracket assembly) operation, has been detected.
    In this situation, the following control is performed:
    Reason for warning:
    Malfunction detection
    Warning Start Condition (One of conditions is met):
    The steering lock ECU (steering lock actuator or UPR bracket assembly), driver of the certification ECU (smart key ECU assembly) or unlock detection switch is malfunctioning.
    An IG relay output circuit malfunction occurs three times or more consecutively.
    The vehicle speed is judged as abnormal or vehicle speed signal communication is malfunctioning.
    Warning description:
    Buzzer in combination meter assembly sounds once.
    "Smart Entry & Start System Check" is displayed on multi-information display in combination meter assembly for 15 seconds.
    Warning Stop Condition:
    The system returns to normal.
  11. Jun 7, 2020 at 9:16 PM
    Jcmartin11b
    Justin
    Los alamos,NM
    22 Tundra Trd Pro
    Oh boy this is going to be a fun thing to tackle
    mutely likes this.
  12. Jun 9, 2020 at 11:04 AM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Disconnect your car battery for 30 minutes and replace the fob battery during that time...this is the first path of least resistance. Only use the fob with the replaced battery until certain issue is gone.
  13. Jun 9, 2020 at 11:18 AM
    Jcmartin11b
    Justin
    Los alamos,NM
    22 Tundra Trd Pro
    Will try this out this weekend when i get home.
    N2DesignsInc[QUOTED] likes this.
  14. Jan 11, 2021 at 7:51 PM
    MBerner
    MBerner New Member
    Matthew
    2020 Tacoma TRD Off-Road
    Any update on this? I am getting the same error in my 2020 the day I had a dashcam installed.
  15. Mar 1, 2024 at 9:52 AM
    XenoTaco
    XenoTaco New Member
    Francois
    2021 Gen 3 TRD Sport Tacoma
    Light bar, level kit.
    Update?
