Smart key not detected
Discussion in '3rd Gen. Tacomas (2016-2023)' started by slowpoke16taco, Sep 25, 2017.
  1. Sep 25, 2017 at 8:09 AM
    slowpoke16taco
    slowpoke16taco [OP] Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    Weird situation here...just me venting / wanting to know if anyone else ran into this issue?
    So the other day I drove to the market, parked the truck, and turned off the engine. The dash started beeping, showing the message "key not detected" and the engine warning light flashing. I exited the truck and tried to lock the door but it wouldn't let me, and the warning was still on the dash screen. I go back into the truck and press Start, and the truck starts right up like normal! I drive it to another parking stall, shut it off, and beep...beep...beep...??!! Of course my next step was to get onto Tacomaworld to look for a solution ;). Saw threads about being locked out, or driving away without the smart key, but nothing like this.
    I just left my truck unlocked, go into the store and return 20-mins later. Just to check, I pressed the unlock on my fob, and the truck responded! Everything back to normal now, hasn't happened since.
    btw, 2016 TRDOR, automatic with push to start. Remote start (12volt.solutions) and Anytimebackup mod.
  2. Sep 25, 2017 at 8:11 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    If it happens again, then I’d worry.
  3. Sep 25, 2017 at 8:54 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Take it to the dealer asap and don't wait- I bet the next time it happens is when you are off-roading it 20 miles from nowhere and your buddies don't notice you are not following them anymore.
  4. Sep 25, 2017 at 9:09 AM
    slowpoke16taco
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Good point. I was most likely going to bring up the issue with the dealer, definitely now sooner than later.
  5. Sep 25, 2017 at 9:35 AM
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    I've had issues where if my key is under my phone in my pocket it can't be detected.
    xxTacocaTxx and Simpleton like this.
  6. Sep 25, 2017 at 9:42 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    battery getting weak in your keyfob would be my guess.
    bv8ma, Gator352, jss1975snow and 5 others like this.
  7. Sep 25, 2017 at 10:01 AM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    You guys know there's a physical key inside the fob right?? You don't need to worry about leaving your truck unlocked you can manually lock/unlock it with the actual key. And even if your FOB is completely trashed you can still hold it right up next to the start button and it will start the car, I removed my FOB battery just to really test it and it still works.
    It sounds like your truck is trying to warn you that your FOB battery is getting low, just replace the FOB battery and go from there.
    FYI if you keep your key fob consistently near your cell phone/laptop/any device that generates a magnetic field it will constantly try to interact with it and kill your battery a lot faster.
    Another thing to be aware of is environmental background noise, if you're near a cell phone tower, radio tower, or any other high powered transmission device your key FOB will likely be overpowered and not able to transmit to your truck, so again use the manual key and hold the fob next to the start button to get around it. Its the reason almost no ones car alarm works on Mt Soledad (there's a bunch of radio towers up there and I constantly see people think they're "locked out").
    Aqualoon, STrooper, mopar2 and 10 others like this.
  8. Sep 25, 2017 at 10:13 AM
    rodrigger
    rodrigger Active Member
    Canada, BC
    2017 Tacoma TRD Sports Upgrade
    good information jaque8. thanks
  9. Sep 25, 2017 at 10:26 AM
    OnHartung'sRoad
    Uh, I can get in the back with that key but I don't fit through the slider :( as my truck has keyless handles (2017).
    The problem may also be an intermittent loose keyfob battery connection - should check the battery clips too.
  10. Sep 25, 2017 at 10:33 AM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    :facepalm:
  11. Sep 25, 2017 at 10:44 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    What's that "hole" thingy in your door handle...???
    xxTacocaTxx and Bleep100 like this.
  12. Sep 25, 2017 at 10:45 AM
    OnHartung'sRoad
    Huh, how quaint. I never used or noticed those before on mine!
  13. Sep 25, 2017 at 10:55 AM
    Jaque8
    2017 Inferno TRD OR
    Wait wait wait yours doesn't have a keyslot at all!?! I've never seen that before, you sure its not just covered under the plastic part on the door handle??
    That's crazy if you don't have one at all
    edit: nevermind looks like you just didn't notice, don't feel bad it happens all the time! I've shown people that have owned a prius for YEARS their keyhole and they're SHOCKED they never saw it before lol
  14. Sep 25, 2017 at 11:50 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Yeah, and we're gonna let technology take control of our vehicles (not to mention our lives) in the near future. Not for me thank you very much. Can't even rely on tech to open doors and start the engine.
    OnHartung'sRoad likes this.
  15. Sep 25, 2017 at 12:11 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    I didn't even get one of the magic key fobs. My Taco is such an outdated piece of shit. :(
  16. Sep 25, 2017 at 12:15 PM
    OnHartung'sRoad
    sabotanker likes this.
  17. Sep 25, 2017 at 12:18 PM
    OnHartung'sRoad
    Yeah, but guess whose going to be giving us rides when our trucks don't start because the fob is broken?
  18. Sep 25, 2017 at 12:21 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    This, Even when im outside the truck if the fob is between me and my phone It wont even unlock until i move it around in my pocket
    xxTacocaTxx likes this.
  19. Sep 25, 2017 at 12:22 PM
    Simpleton
    Orange County
    2017 DCSBOR
    None as of yet
    just hold the remnants of the fob to the push to start button and it has a passive RFID that will allow you to start the truck.
  20. Sep 25, 2017 at 12:31 PM
    OnHartung'sRoad
    That's cool, unless you're my wife. We were working out in the desert and everyone wanted to put their lunch boxes under the truck in the shade, so I recommended to her to put the keys in one of the lunch boxes so she wouldn't accidentally run them over. Well, she broke the alarm fob when she ran over all the lunch boxes (She couldn't find her key, so got the spare out of her pack!)
