Smartphones that actually connect & charge
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pltommyo, Oct 27, 2017.
  1. Nov 1, 2017 at 2:51 PM
    #41
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    iphone 6 and a Dogbone case. Charges fine every time.
  2. Nov 1, 2017 at 2:55 PM
    #42
    H3ATH3N2016
    H3ATH3N2016 Soul Stealer
    Bren
    Jones County, Ga
    2016 DCSB TRD SPORT 4x4
    9"+/- Lift, 20" Dropstars, 35x13.50x20 Toyo Open Country M/T, Predator Tube Rails, Ultimate LED signal lights, Much Much More
    iphone7 no prob really with entune, no wireless charging capability with the 7 however, without the Qi case, .... and I like my Otterbox way too much for that
  3. Nov 27, 2017 at 9:03 PM
    #43
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    For anyone with an S7, does having a case on the phone effect the wireless charging performance?
  4. Nov 28, 2017 at 8:51 AM
    #44
    crdnlplt
    crdnlplt Well-Known Member
    SE PA
    17 dcsb trd or
    Works great for me! Love the charger! I just wish whatsapp worked a little better with entune.
  5. Nov 28, 2017 at 9:18 AM
    #45
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    I have an 8 Plus, charged through a case 100% of travel. 20 minute drive only charged 1%
  6. Nov 28, 2017 at 9:21 AM
    #46
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    iPhoneX with Apple OEM case.
    • Mine charges fine. (my case is ~1mm thick) - do your math though, inductive charging decreases as the square of the distance so 3 mm can theoretically be 9 times less powerful, if you assume per the spec that Qi1.0= 1 amp at 0mm distance (58.4 C /137 F), you want it as close a possible...most chargers will give 1 amp at 1.2mm and the current rule of thumb is "works" at 3 mm but that is likely about 55% degradation or about .45 amp. I do not believe the Taco Qi pad is the 'fast charger' 15 amp. pad. Also, being Centered on the pad is key. Even a 5 mm off-center can, per spec, degrade the charge a lot (<>50%)
    • Entune has been flaky with prior iPhones 5s and 6, so I abandoned it and have not tried again.
    • I do pair to use for AppleMusic and Siri: I also find paring is best done twice...connect...restart phone, disconnect...connect...restart phone, then the "rapid skipping" goes away, have had this on all phones...likely a paring issue where it tries to cache data on the radio and gets messed up.
  7. Nov 28, 2017 at 9:21 AM
    #47
    PeteK
    PeteK Well-Known Member
    Brockton, MA
    2017 Cement Truck
    Galaxy S7 Edge has worked flawless.
  8. Nov 28, 2017 at 9:22 AM
    #48
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    S8 works just fine.
  9. Nov 28, 2017 at 9:49 AM
    #49
    SirRoytzz
    SirRoytzz Taco Enthusiast
    Have an iPhone X and it charges well in my Taco
  10. Nov 28, 2017 at 10:46 AM
    #50
    Hogpauls
    Hogpauls Hmmmmmm.
    Near Boise
    '16 Tacoma BBP TRD OR Dbl cab mt ftw
    I’m using the UAG case and it charges pretty well. Every so often it won’t charge, I get the double blinking light at the charger.
  11. Nov 28, 2017 at 10:52 AM
    #51
    ricetime
    ricetime Member
    Uncle T
    Same here with S7.. Just had to get a thinner case....No otterbox
    shakerhood[QUOTED] likes this.
  12. Nov 28, 2017 at 11:39 AM
    #52
    swimmer
    Tucson
    2016 TRDORAC4WD
    Which case is working for you?
  13. Nov 28, 2017 at 11:48 AM
    #53
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Page 422 of my owners manual: Flashing is per spec...when they get too hot, the phone postpones charging until cools...or stops at ~80% or both. Remove from charger so it cools "completely" and then return. This is not avoidable as magnetic induction is inefficient and causes more heat, so rather then overheat the "safety" kicks in. You can leave it on the pad but it will cycle back and forth...faster to top if you cool the phone and it then finishes in one step.
    From my note above:
  14. Nov 28, 2017 at 1:54 PM
    #54
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    Same with me.
  15. Nov 29, 2017 at 10:58 AM
    #55
    ricetime
    ricetime Member
    Uncle T
    Unicorn beetle
  16. Nov 29, 2017 at 11:10 AM
    #56
    swimmer
    Tucson
    2016 TRDORAC4WD
    Thanks a lot.
    ricetime[QUOTED] likes this.
  17. Nov 29, 2017 at 11:23 AM
    #57
    SilverTacomaGuy
    SilverTacomaGuy Well-Known Member
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    Little tree air fresheners. Clazzio black leather seat covers.
    Samsung galaxy s8 plus works GREAT! No problems at all with it.
  18. Nov 29, 2017 at 11:26 AM
    #58
    SilverTacomaGuy
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    I have th
    I have an s8+ with the UAG case and I've never experienced any charging problems. I've had the phone since pre order.
