Smashed 7 pin trailer connector
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BKinzey, Sep 2, 2016.
  1. Sep 2, 2016 at 2:33 PM
    BKinzey
    BKinzey [OP] Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Crunched it pretty good. I'll be looking to relocate it in the near future but for now I want to replace the connector. I know I can order a stock replacement harness but all I really need is a new plastic body, the wiring, pins and connectors are in good shape.
    Anybody use an aftermarket body to do this?
    Thanks.
  2. Sep 2, 2016 at 2:35 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Yes I got the hopkins 7 plus 4 way replacement from Amazon or etrailer, 21$ as opposed to $150+ for the stock harness/connector replacement, i believe toyota does sell just the plastic piece but it is 50$+, some people have had luck using the 2016 7x4 as well
    EDIT- below is the correct one I used, it has a dust boot
    http://www.etrailer.com/Wiring/Hopk...XIE4IzklUh6cdmuTC_VfsSyUv0p6f3aWVoaApki8P8HAQ
    Relocating it makes sense as well, as you have discovered it is exposed to damage in the stock location
  3. Sep 2, 2016 at 2:57 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    How did you smash it? With my ball hitch extended out, I cant see how the plug would get crushed
  4. Sep 2, 2016 at 3:01 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  5. Sep 2, 2016 at 3:06 PM
    IronPeak
    AuggieX
    Back to Back
    It is easy to do, and a very common occurrence on the 2nd gen. the connector drags on the ground and is destroyed, relocating it before it happens is ideal.
  6. Sep 2, 2016 at 3:53 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Ideally I'd like to take this one apart and use the case/enclosure of a new one. No wire cutting or splicing. I'm looking for someone who has done it and can maybe suggest a brand to use. I've seen several under $10 but it's hard to tell if they can be taken apart or not.
    Secondary to that I can always cut the wires and crimp the new one on.
  7. Sep 2, 2016 at 4:15 PM
    IronPeak
    AuggieX
    Back to Back
    The one I recommended requires no splicing, but you would need to cut and strip the end of the harness. It has screw style wire clamps, you can see them in the photos in the link. I found it easy to do.
  8. Sep 2, 2016 at 4:18 PM
    IronPeak
    AuggieX
    Back to Back
    This is a pic of the rear, and it includes a dust boot that covers the connections and wire. It also has 4 flat, eliminating the need for an adapter (10$, and easily lost) 4 flat covers most utility trailers
    Fastbilly5 likes this.
  9. Sep 2, 2016 at 4:26 PM
    IronPeak
    AuggieX
    Back to Back
  10. Sep 2, 2016 at 6:21 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I second getting one with screws. It's a lot less hassle than having to mess with crimp style ones. Chances are you'll have to cut the wiring anyways to install a new 7-pin connector.
    koditten likes this.
  11. Sep 2, 2016 at 6:40 PM
    koditten
    Kirk
    Central Michigan
    This is the best answer.
    If you don't have experience soldering and using shrink tubing.this is a perfect opportunity to perfect your skills.
  12. Sep 3, 2016 at 9:00 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    How hard was it to drill the hole?
  13. Sep 4, 2016 at 3:30 PM
    IronPeak
    AuggieX
    Back to Back
    I used a dremel with a cutoff wheel, I should have used a hole saw but it was what I had on hand, not to hard t h e metal is thin there
    Bruce988jl[QUOTED] likes this.
