Smell after header install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ironman_jon, Dec 31, 2010.
  1. Dec 31, 2010 at 5:18 PM
    ironman_jon
    ironman_jon [OP] Well-Known Member
    Jonathan
    Prerunner Sport
    URD TCAI Wicked Flow 18" 2 10in alpine type r 1500 watt amp MB 72 matte black Custom Bumper Debadged Glassworks fenders McNeil bedsides Helix TB Spacer Intake Manifold Spacer Custom Roof Rack 5x 55w HID SK2 projectors 55w DDM 5k Bulbs Camburg Long Travel Fox Coilovers
    I installed the DT headers on my truck about 2 weeks ago . Ive noticed that the truck smells as if it is running rich. Could that be because the removal of the cats on the stock manifold? Since then the 02 sensor on the passenger side header went out. i need to replace that in the up and coming weeks. Could that o2 sensor be the cause of it running rich? Also what are the effects of that o2 sensor being out
  2. Dec 31, 2010 at 5:36 PM
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    I know when I installed my flowmaster 40 on my 1st gen I got a weird smell, almost like a really really rich burn. I did some research and talked to a local guy and it turned out it was just the "break-in" smell. Should only stick around for 3-4 days, if your worried, open her up on the free way and hit 70 for a little.
    However, im not sure if headers do the same thing. Id look into that o2
  3. Dec 31, 2010 at 5:41 PM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    Yes I believe they will run rich (at times) with the O2 sensor out. The computer goes into "closed loop" operation.
  4. Dec 31, 2010 at 5:45 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
