Smell gas in dipstick
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allex95, Aug 3, 2020.
  1. Aug 3, 2020 at 1:22 PM
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    So recently my gas mileage as tank to 13mpg and my spark plugs are fouled with carbon. So I’m thinking the iac valve is not working not allowing enough air or a leaky injector. Smell of oil on dipstick. No check engine light Please advise really stuck:facepalm:
  2. Aug 3, 2020 at 1:30 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Smell of oil or of gas? Because it should smell like one and not the other.
  3. Aug 3, 2020 at 1:34 PM
    Allex95
    allex
    Smell of gas dipstick isn’t higher or anything but smells like gas on dipstick
  4. Aug 3, 2020 at 1:34 PM
    paetersen
    paetersen Well-Known Member
    taking that sentence as a typo and you really meant 'smell of gas on dipstick' look for leaky injectors or a bad fuel pressure regulator leaking fuel into the intake manifold.
    Gunshot-6A likes this.
  5. Aug 3, 2020 at 1:35 PM
    Allex95
    allex
    Well it does smell like a gas on the dipstick. The level on the dipstick is fine not going any higher.
  6. Aug 3, 2020 at 1:38 PM
    paetersen
    get it fixed asap and change your oil- fuel wash will really wreak havoc on your oil's ability to keep things lubricated- specifically your piston rings.
    wilcam47 likes this.
  7. Aug 3, 2020 at 1:44 PM
    Allex95
    allex
    Well I have to find the problem before changing oil... spark plugs are covered in carbon
  8. Aug 3, 2020 at 1:44 PM
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    The best way to tell if gas is in your oil is to drain a little into a styrofoam cup. If there is gas present, it will melt the bottom of the styrofoam cup.
  9. Aug 3, 2020 at 1:45 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    How's the engine temp? If the thermostat stuck open you could be stuck in warm up mode. This causes bad mileage and excess fuel delivery that can cause that smell. Also fouls plugs
    billybop90 and wilcam47 like this.
  10. Aug 3, 2020 at 1:46 PM
    Allex95
    allex
    Engine temp is normal 186-190.
  11. Aug 3, 2020 at 1:47 PM
    paetersen
    a quick (but not always 100%) way to check the FPR is to pull the vacuum hose that goes to it- if it smells like gas, or especially if it is wet with gas, the diaphragm is torn and there's your problem.
  12. Aug 3, 2020 at 2:03 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    there could be a ' leaky' fuel injector........that alone would not cause carbon on the plugs
    check Ur plugs...... the bad cylinder of course will look worse
    all cylinders should Not look bad
    if they do look funky thats NOT 1 bad injector !!
    smell of ' gas ' in the oil would not necessarily increase the crankcase / dipstick
    the amount of fuel loss .....washing the cylinder walls getting blown by the rings
    will contaminate the oil yet quite a bit will evaporate
    be certan NOT to jumble parts
    #1 injector the exact same as #1
    #1 sparkplug stays Same as #1 spark plug
    good luck
  13. Aug 3, 2020 at 2:10 PM
    Allex95
    allex
    Yea all spark plugs have carbon on it. Having someone check my valve clearance as well. My mpg as dropped from 17 to 13
  14. Aug 3, 2020 at 2:17 PM
    ROAD DOG
    FEW
    if ALL the plugs have deposits..........unlikely all injectors are bad
    they are all firing in error
    any recent work done to engine ???
  15. Aug 3, 2020 at 2:20 PM
    Allex95
    allex
    Not that I know of. I possibly think the IAC valve is stuck. I have no engine codes showing up
  16. Aug 3, 2020 at 2:21 PM
    ROAD DOG
    FEW
    how many miles on engine
    why do U suspect IAC valve ????
  17. Aug 3, 2020 at 2:22 PM
    Allex95
    allex
    327k rebuilt at 290k but it just started getting bad mpg and carbon plugs. Because I hear air escaping it sounds like near the throttle body
    Getting the valve clearance check that could do it I heard possible
  18. Aug 3, 2020 at 2:26 PM
    ROAD DOG
    FEW
    unlikely the valves
    after the rebuild it would have been evident then
    there again unlikely ALL are out of adjustment
    unless during rebuild they were ALL installed in error
    compression/leak down would tell
    valves out adjustment wont eliminate gas in the crankcas or smell
    why U suspect IAC ??
  19. Aug 3, 2020 at 2:27 PM
    Allex95
    allex
    Because I have a rough idle slightly, and I hear air escaping near under the throttle body. also I did a compression test and all cylinders within 180s
  20. Aug 3, 2020 at 2:31 PM
    ROAD DOG
    FEW
    aint likely U could test 180's with valves out adjustment
    if U hear air/vacuum leaks..............not valves either
    if U hear air/vacuum leak after quite a few miles......................stop Guessing
    back track in that area
    check & double check
    even a vacuum leak wont leak gas into the crankcase
    could actually throw off a sensor resulting in the ECM or MAF metering & compensating in error
