Smindle damage -- urgent reply needed
Discussion in 'Towing' started by Peru, Oct 23, 2011.
  1. Oct 23, 2011 at 3:56 PM
    Peru
    Peru [OP] Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Hello Everyone,
    I am in urgent need to resolve a major problem
    can i mount new bearing on the spindle below or am i asking for trouble. While installing the electrical brakes i discovered this (see below)
    i need to do 3000miles to mexico this week
    thanks in advance
  2. Oct 24, 2011 at 10:16 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Any way you could make those pictures bigger? They're too small to really see what's going on.
  3. Oct 24, 2011 at 11:22 AM
    Peru
    Jonathan
    Redmond WA
    none
  4. Oct 24, 2011 at 11:58 AM
    monster38
    monster38 Member
    Michael
    I would like to point out that in addition to the bearing having been spun, the grease seal race is also damaged. If at all possible, it would be *better* to get that axle repaired, but as long as the bearings actually spin freely, there shouldn't be any risk of failure. Make sure its greased well, and that the bearings are TIGHT. Check the wheel occasionally for side-to-side motion, and tighten if any develops.
    My feeling is that it should be fine, but its obviously your call. In the least, I would bring some spare parts along (probably a good idea anyway).
  5. Oct 24, 2011 at 2:37 PM
    Peru
    Jonathan
    Redmond WA
    none
    Thanks for The info. Its much appreciated
    One other question. I couldn't find a washer the goes between the outer bearing and the castle nut that has a lip on the outer edge. I bought a standard washer with same dimensions but with out the lip. It's a zinc plated washer
    Can anon thing of a reason not to use it. The lip does not look like I serves a function
    Thanks again
  6. Oct 25, 2011 at 6:18 AM
    monster38
    monster38 Member
    Michael
    I wouldn't worry about it, I've never even heard of it having a lip. Definitely never seen one and can't imagine a purpose for it. Could it have been a "spare washer" that a previous owner installed on it?
  7. Oct 25, 2011 at 8:48 AM
    Peru
    Jonathan
    Redmond WA
    none
    I am not sure -- I don't think the previous owner ever changed them so the lip could be where the bearings race spun on the washer creating a lip. Both sides are pretty much the same but one side is in bad shape so it's kindof hard to tell
    I agree with you I can't see how using it would be a problem but I am moving out of the country, prepping my house for a sale that thanks to the poor market won't happen and getting all my legal stuff squared away for visas and selling all the toys I've accumulated over the years makes for a situation where even simple decisions can be more complicated.
    Thanks for the info
  8. Oct 25, 2011 at 8:52 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    lol smindle
  9. Oct 25, 2011 at 9:40 AM
    monster38
    monster38 Member
    Michael
    If that's the reason for the lip, you certainly should put new washers on both sides.
    Glad to help, and good luck with the move.
