Smitty Built Hitch Mounted Winch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jackrules, Apr 4, 2014.
  1. Apr 4, 2014 at 9:04 PM
    jackrules
    jackrules [OP] Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    Hi All,
    Sorry for starting a second thread, but the discussion changed somewhat in my other thread and I so I thought this was necessary.
    I do light offloading on generally hard surfaces in open spaces. I do know that a hard surface can change to sand very quickly though and get one stuck. The winch wouldn't be used much, but it would be incase I ever get into soft sand and get stuck. Generally I'm not in steep or tight places so concerns of not being able to fit the winch into the trailer hitch don't really apply to me. I've not ever been in a situation where winching backwards would not be an option. I'm more of an overland than a rock crawler and am generally off road for camping or getting to places for dirt biking. I drive a pre-runner and am a cautious driver. In the future I plan on getting something with 4WD, or possibly a trail dedicated truck (where I wouldn't be afraid of body damage) – but right now, I like to get off the beaten path and be safe doing so.
    I've looked a little into come-alongs, but they seem too slow and I'm worried I wouldn't be strong enough to really get my truck out if it got really stuck. They also seem more dangerous.
    By the sounds of what I do, do you think that a winch would be excessive? Should an off road jack of some sort, like the ARB Inflatable Jack and some thick rubber be enough to get me out of one of these situations?
    Or if I'm spending that much already, should I be putting the money towards a winch?
    Why are 24' Winch Wiring Kits so expensive? The Wire can't add up to near $100??!! What gage wire would be necessary for a winch?
    I'd like to stay within a $500 budget!
    I am looking at getting the Smittybilt Winch Cradle and either a Smitty Built XCR 8 or an Engo 9000 winch.
    Smittybilt Winch Cradle $120: http://www.smittybilt.com/product/index/159.htm
    Smittybilt XCR 8 $300: http://www.smittybilt.com/product/index/38.htm
    Engo 9000 $325: http://www.amazon.com/E9000-Engo-Electric-Winch/dp/B00570XMRG
    Engo 9000 Review:It beat out many $1000 competitors. http://www.fourwheeler.com/how-to/129-1107-massive-multi-winch-shootout/
  2. Apr 5, 2014 at 5:29 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I wouldn't get inflatable jack. If anything a couple of traction aids like maxtrax may be more beneficial. Link is an example, I know the maxtrax are expensive.
    http://mobile.dudamobile.com/site/maxtrax?url=http://www.maxtrax.com.au/#3031
    Instead of getting a wiring kit, may be cheaper to source 0 gauge welding wire, with disconnects and just crimp it all yourself. Don't know how much cheaper it will be but hey everything helps.
    http://accessories.etrailer.com/trailer/Winch Quick Disconnect disconnects aren't that expensive.
  3. Apr 5, 2014 at 8:02 AM
    CaliBluTaco
    CaliBluTaco Well-Known Member
    Nathanael
    Ohio USA
    07 Tacoma TRD Off Road
    Brute Force Fab Hybrid Front Bumper, Brute Force Fab HC Rear Bumper, All Pro Kickout Sliders, Pelfreybilt IFS Skid and Mid Skid, Relentless Fab Tailgate Reinforcement, ICON Ext.Travel Coilovers w/ 14"x 650# Eibach coils and custom valving, LR UCA's, OME Heavy Duty Rear Leaf Pack w/ All Pro U-Bolt Flip, Icon 2.0 Aluminum Series Extended Travel rear shocks & Wheelers Super Bumpstops. 285/70R17 Hankook Dynapro MT RT03 Tires on 17x8 Pro Comp 7089's, ENGO E12000s Winch w/ Synthetic Rope, Locker Anytime Mod, Rear Diff Breather Mod, and more...
    Personally, if you can afford a winch and you do go off roading, then i would say a winch is great to have. Just my 2 cents.
    As far as what brand winch, i have heard very good reviews on the Engo winches and im actually thinking of getting one myself. Been researching for months now and the Engo ( I think ) is the best bang for the buck and seems reliable and built well. Also great customer service!
    I know with Smittybilt, a lot of guys have to seal the solenoid because of corrosion in the electrical connections. Also the grease in the gears is not the best and many guy's take them apart and clean and repack with a better grease. But they seem like a decent winch for the money. I know Smittybilt just came out with a Generation II winch series as well, both the XRC version and the X20. Worth checking into. Hope this helps you out :)
    You can get an Engo 9000 for under $300 here: http://mudflaps.com/i-7825604-engo-77-09000-e9000-9000-lb-12-volt-electric-winch.html
  4. Nov 17, 2014 at 1:43 PM
    itsmemattp
    itsmemattp Well-Known Member
    Ashland, Oregon
    06 Tacoma Access Cab 4x4
    OP- Any update on what you went with and how its working?
