Smittybilt XRC8 or XRC10?
Discussion in '1st Gen. Tacomas (1995-2004)' started by brettb, Apr 4, 2011.
  1. Apr 4, 2011 at 10:56 AM
    brettb
    brettb [OP] Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Im going to be getting a winch this summer, and its not going to be used too much but should I get a 8,000 max limit or a 10,000 max limit? I'm probably going to be pulling either myself out, or friends who I go offroading with. They are all medium trucks like my tacoma or a mid SUV. I might pull out smaller fullsize trucks. So Should I get an XRC8 or be on the safe side and get the XRC10
  2. Apr 4, 2011 at 10:58 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I think you should be fine with the 8000lb but the 10000lb wouldn't hurt if your willing to have the extra weight on the front of your truck.
  3. Apr 4, 2011 at 10:59 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    8 with a snatch block
  4. Apr 4, 2011 at 12:22 PM
    brettb
    Brett
    Laramie, Wyoming
    '99 Tacoma
    How much more will the 10,000 be?
  5. Apr 4, 2011 at 12:36 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Get the 8,000 and a snatch block. Problem solved.
  6. Apr 4, 2011 at 12:41 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Check the specs. The 10 has the same motor as the 8, just a little lower gearing. So the 8 will have a little faster line speed.
  7. Apr 4, 2011 at 12:42 PM
    JLee
    Jerry
    Benicia, CA
    100 bucks but I would just get the 8,000 and a good snatch block you could pull more then 10,000lbs
  8. Apr 4, 2011 at 12:46 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    I have had no problems with my 8. Haven't stalled it yet.
  9. Apr 4, 2011 at 1:57 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    i think he might have been refering to the extra weight of the 10K vs the 8K that you made reference to
  10. Apr 4, 2011 at 6:22 PM
    brettb
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Yeah i was. But I think I'll follow everyone and get the 8 and a snatch block.
  11. Apr 4, 2011 at 6:22 PM
    brettb
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Which one?:D
  12. Apr 4, 2011 at 7:52 PM
    JasoTaco
    I would in no way consider myself an expert when it comes to recovery equipment. With that said the different types of pulley / snatch blocks accomplish the same thing it all comes down to the ratting. I would always recommend doubling the rating on the block to what your winch is. For example if you have a 8000 winch get a block rated to at least 16,000.
    I’m new to winches but have done fair amount of research to be safe and practice proper winching techniques. I learned a lot from watching this series on youtube. It’s definitely worth your time.
    http://www.youtube.com/user/4x4Training#p/u/9/6YscTH3JF68
  13. Apr 4, 2011 at 11:05 PM
    brettb
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Thank you very much!
  14. Apr 5, 2011 at 6:39 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Warn M8000.
  15. Apr 7, 2011 at 7:39 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
    Smittybilt makes a nice Snatch Block. I use them all the time.:)
