Smittybuilt Roof Racks or another route
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jstyle, Jun 2, 2017.
  1. Jun 2, 2017 at 7:04 AM
    jstyle
    jstyle [OP] Well-Known Member
    Josh
    2012 Taco Off Road
    Anything that was shiny is now black
    So I have a 2012 Double Cab Off Road... and I want a Roof basket type solution.
    Right now I don't have rails or crossbars or anything so I figured the best route to go would be to get the SmittyBuilt Roof basket. If I get that it looks like I don't have to get anything else, is that the case?
    https://www.realtruck.com/smittybilt-defender-roof-rack/R184155P2012Y608MA.html
    Anyone recommend getting rails, then cross bars, then a basket from like Rhino or whatever? I like the SmittyBuilt solution because Warrior and Fab Four are quite a bit more expensive.
    I'd like to NOT drill into my roof but it's not a hard stop. I'd also like to be able to carry around 150lbs up there. I'm getting it because my Yeti 105 won't fit under my tonneau cover.
  2. Jun 2, 2017 at 7:06 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I believe you have to drill for that
    Get a prinsu and it bolts right in
  3. Jun 2, 2017 at 7:11 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    I'd say that the "quietest" solution regarding wind noise is the OEM. However, there are very few baskets that work with it.
    The best all around is Prinsu, but it doesn't remove. It can hold 200lbs or more I think on a DC roof.
    Bars + basket is going to be pretty high, create an air gap between the vehicle and the cargo, and probably whistle the loudest.
    Expect 1.5 - 2 MPG drop due to wind resistance.
    Another thought, which I'm doing, is to do bed bars and mount it back there. No wind noise, better aerodynamics. You situation may be different, however.
    Best of luck in your searches.
