SMKYTXN'S 2011 DCFBFTMFW Solid Axle Swap
Discussion in 'Solid Axle Suspension' started by SMKYTXN, Jun 18, 2017.
  1. Jun 18, 2017 at 3:05 PM
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    DONE....ish
  2. Jun 18, 2017 at 3:05 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    I figure I'll start this off with the parts list. You don't realize just how much crap goes into this swap until you start keeping track of the orders.
    Front Axle
    1994 Ford Dana 60
    ARB RD167
    RuffStuff D60 Diff cover
    Knuckle machining and high steer arms - Four Wheel Supply
    5.38 gears - Yukon
    Install Kit - Yukon
    Yukon Hardcore hubs
    Artec Ram Mount
    Chromoly axles - USA Standard 35 spline, spicer ujoints
    Drive Flange - High angle driveline
    Three link brackets - Rock Solid Toys
    Lugnut4x4 3/4ton disc brake kit
    Rear Axle
    2000 GM Express Van 3500 14 Bolt
    ARB RD115
    14Bolt Pinion Guard - Ruffstuff
    +2 Perch Kit - Ruffstuff
    Side mount lower shock mount - Ruffstuff
    Disc brake swap - Lugnut
    5.38 gears - Yukon
    Master Install Kit - Yukon
    Shave kit - Barnes4wd
    Drive Flange - High Angle driveline
    All the other goodies
    Tire Beads - 15oz per tire
    Traction bar kit - Ruffstuff
    Internal Roll Cage - 4xinnovations
    ORI's - 14", blue anodized, integral reservoir
    Hutchinson Dual Beadlocks
    Pitbull Rocker Radials - 41.5x13.5x17
    Miscellaneous
    Lug Nuts - ET Ultra Tapered 60
    Upper and lower ball joints
    Delrin spindle bushings
    Shock mounts, spacers, etc.
    pc3coyote, Biscuits, Slashaar and 9 others like this.
  3. Jun 18, 2017 at 3:05 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    94 Dan 60. This one still needs to head to the sand blaster.
    Pulled the knuckles. The plan is for full hydro, so I need hi-steer arms. The fun part of every ball joint knuckle is that there isn't provisions for the arm, so off to the machine shop they went.
    14Bolt out of a 2000 3500 van. 68.5wms
    With two sets of hands these weren't too bad to put together. We got it down to 15minutes each.
    Shaving the 14Bolt
    My 14Bolt ended up with a drain plug, something that most people haven't seen. So that made for an interesting shave since the drain plug had to be filled.
  4. Jun 18, 2017 at 3:06 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Received the knuckles back from 4wheelsupply today. 7/26/17
    Photo Jul 26, 10 32 46 PM.jpg Photo Jul 26, 10 33 11 PM.jpg Photo Jul 26, 10 32 59 PM.jpg
    8/14/17 update
    I made some real progress this weekend. The 14Bolt is under the back end and all of the IFS components are off of the truck.
    To keep the pitbulls from eating the cab I used the Ruffstuff offset spring hanger. This allowed me to push the rear axle back 3".
    Of course I had to put a tire under the fender after the IFS was out on that side.
    Those pitbulls don't look so big when they're tucked under.
    Buh bye IFS
    The entire PS system came out in one piece. I didn't see an easy way to remove the fluid without making a mess so it all came out together.
    Slowly making room for activities. Next weekend will be the plasma cutter weekend. I'm not looking forward to that at all.
    8/19/2017 Update
    I managed to get all of the IFS cut out today. What an absolute pain! I still have to cut out the transmission cross member, but that will have to wait till I get my link brackets in. I'll be adding in a couple of temporary cross members to keep the frame square.
  5. Jun 18, 2017 at 3:06 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    One
    ChadsPride likes this.
  6. Jun 18, 2017 at 3:06 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    As
  7. Jun 18, 2017 at 3:06 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Well
  8. Jun 18, 2017 at 3:08 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  9. Jun 18, 2017 at 3:08 PM
    Enjoihavok
    Enjoihavok Never Forget Z.S.
    Erik
    Chandler, AZ
    2021 Tundra Pro
  10. Jun 18, 2017 at 3:13 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
  11. Jun 18, 2017 at 4:15 PM
    Spintly
    Spintly Well-Known Member
    Greg
    Home of the Groundhog
    85 Single Cab Pickup & 2000 911
    Sub'd :thumbsup:
    ChadsPride and SMKYTXN[OP] like this.
  12. Jun 18, 2017 at 4:16 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Pics as it sits now
    :worthless:
  13. Jun 18, 2017 at 4:21 PM
    shawnMc
    shawnMc Well-Known Member
    Shawn
    Santa Barbara
    2009 Tacoma regular cab 4x4
    What kind of frame height are you going for on this? Those tires are huge!
    Are you keeping the 63s in back, or linking it?
  14. Jun 18, 2017 at 4:22 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Dammmn!!
  15. Jun 18, 2017 at 4:27 PM
    Wolftaco0503
    Adam
    Chicago
    So that's were all of our patch money is going! WAY TO GO @SMKYTXN
  16. Jun 18, 2017 at 4:32 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Negative ghost rider! Hell, I'm not even going to cut into the truck until mid July due to a work trip. This is all just a tease!
    The 63's are staying for this round and the front will be a 3 link. I'm looking at a frame height around 23-24".
    Trust me, I've been saving my pennies for a while.
  17. Jun 18, 2017 at 4:34 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Sub'd :drool::drool::drool::drool::drool:
  18. Jun 18, 2017 at 4:37 PM
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Sub'd. Hopefully I don't bump into the back of this after the SAS.....
  19. Jun 18, 2017 at 4:43 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    The partout thread will come much later, but @greeneggsnspam has had dibs on the diffs for a while now.
    greeneggsnspam and ChadsPride like this.
  20. Jun 18, 2017 at 4:46 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
