SMKYTXN's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SMKYTXN, Sep 2, 2012.
  1. Mar 10, 2014 at 6:44 AM
    #201
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I did some reading up on those. It seems they're not in production anymore, but you can still find new old stock. The $70 one on Amazon was made in 2006 and recertified with a 10 year stamp in 2013. If you don't recertify before the 10 years you have to throw away the tank.
  2. Mar 10, 2014 at 6:45 AM
    #202
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    hmm. so as long as you stay on top of things, you're good to go.
  3. Mar 10, 2014 at 6:55 AM
    #203
    SMKYTXN
    Nathan
    Houston
    DCFB
    That's what it looks like to me. I did see a couple of comments about people being refused at their filling stations though.
  4. Mar 10, 2014 at 6:57 AM
    #204
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I'm sure. that's just the good ol' boys being scared of anything that "isn't the way their daddy did it".
  5. Mar 10, 2014 at 7:11 AM
    #205
    SMKYTXN
    Nathan
    Houston
    DCFB
  6. Mar 10, 2014 at 7:11 AM
    #206
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    :woot:
    paint it pink :anonymous:
  7. Mar 10, 2014 at 7:50 AM
    #207
    SMKYTXN
    Nathan
    Houston
    DCFB
    Thought about it, decided against it.
    Maybe this!
  8. Mar 10, 2014 at 7:52 AM
    #208
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's got potential.
  9. Mar 10, 2014 at 7:57 AM
    #209
    SMKYTXN
    Nathan
    Houston
    DCFB
    I want to use a deep red/maroon for the skid, so I flipped the colors. I'll have to paint the skid white, apply a decal, spray with black, and then peel the decal before it drys.
  10. Mar 10, 2014 at 8:02 AM
    #210
    SMKYTXN
    Nathan
    Houston
    DCFB
    Or this...
    Still not thrilled with either, but coming up with more ideas. Definitely want to stick with only two colors.
  11. Mar 10, 2014 at 8:03 AM
    #211
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    well, whatever you go with, i vote the lone star w/ circle on the rear diff :)
  12. Mar 10, 2014 at 8:18 AM
    #212
    SMKYTXN
    Nathan
    Houston
    DCFB
    I need a small projector so I can get the proportions right on the diff.
  13. Mar 10, 2014 at 8:51 AM
    #213
    SMKYTXN
    Nathan
    Houston
    DCFB
    Colin, what paint did you use for your rear diff?
  14. Mar 10, 2014 at 9:03 AM
    #214
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yellow? :eek:
    too drunk of a project to remember. i really didn't try to hard toing that project. wiped down with some alcohol, taped off for the yellow background, sprayed whatever yellow paint i had laying around (probably enamle), then waited an hour and taped/sprayed the bedliner for the black sections.
  15. Mar 10, 2014 at 2:29 PM
    #215
    SMKYTXN
    Nathan
    Houston
    DCFB
  16. Mar 11, 2014 at 8:14 AM
    #216
    SMKYTXN
    Nathan
    Houston
    DCFB
    This past weekend I was able to set up the gopro Hero3 with the wifi connection. It's a fantastic option for controlling the camera, especially since I don't have to get out of the truck to turn the camera on/off, and that I can start recording remotely. The only downside is that the battery life sucks, even with a battery backpack.
    The solution is to hardwire the camera. Here's what I've ordered.
    Cam-Do Battery Eliminator
    The battery eliminator sits in place of the factory battery and provides a female cctv type connector, see below.
    To get power to that connector I'll need the male plug wired to 12volt. The supplied cable is only 11" long so the connector will be exposed to the elements and the cctv connectors are not waterproof.
    I will be replacing the cctv connectors with waterproof electrical connectors similar to those you see on HID's.
    These connectors can be found on Amazon, $8 for a pack of 5.
    I plan on building several different power cables for the camera. One with a cigarette lighter plug, another with ring terminals, and a set with the cctv plugs so I can use an existing battery pack that I have.
    The company that makes the battery eliminator also makes a neat little adapter that allows you to use a full size SD card with the Hero 3. With unlimited power the 2 hours of record time on a 32 gb sd card isn't enough.
    I'll report back once I get the cables built.
    Ugly Betty likes this.
  17. Mar 11, 2014 at 9:13 AM
    #217
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Gonna order the 12v power supply tonight. Thanks for finding it :)
  18. Mar 11, 2014 at 10:23 AM
    #218
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'm always happy to spend your money. :D
  19. Mar 11, 2014 at 11:03 AM
    #219
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you're killin' me.
    It was really fun spending other people's money, until i met Nathan, and he started spending mine :mad:
  20. Mar 12, 2014 at 6:52 PM
    #220
    SMKYTXN
    Nathan
    Houston
    DCFB
    Here are a few more pictures from Shiloh Ridge, courtesy of Matt.
    Looks like it's time for some trimming! I didn't think that 33's would require trimming, but it sure looks like it. The fenders were doing a good job of scraping the mud off of my tires.
    llibrm likes this.
