SMKYTXN's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SMKYTXN, Sep 2, 2012.
  1. Mar 20, 2014 at 9:27 AM
    #241
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Normally an 8' utility trailer. :)
    I rent a travel trailer a few times a year though. I'm towing a 19' trailer to jambo in may and wanted the piece of mind of the controller.
  2. Mar 20, 2014 at 7:30 PM
    #242
    SMKYTXN
    Nathan
    Houston
    DCFB
    No more worrying about the Hero3 battery!
  3. Mar 23, 2014 at 6:11 PM
    #243
    SMKYTXN
    Nathan
    Houston
    DCFB
    Spooling on the wire after a long day of working on the truck. The winch is in and wired. The in cab controls are hooked up as well. I'll get more pictures up tomorrow.
  4. Mar 24, 2014 at 5:54 AM
    #244
    SMKYTXN
    Nathan
    Houston
    DCFB
    Superwinch Tigershark 9500 install
    I installed the winch yesterday. I'm a little OCD when it comes to wiring so it took a bit longer than expected, but it turned out great.
    I used an Amazon lug crimper to attach all of the sealed 1/0 cable lugs. The wire is 1/0 welding lead.
    The crimper has metric size dies so they're not exactly right for the lugs, but if you crimp them 80% and then rotate the lug 90º and continue the crimp you'll get good results.
    Here's the chosen solenoid location. Yes, I sealed the box before installing it.
    Main power lines from the battery. The pelfreybuilt cage is fantastic, but you have to watch those wing nuts. I welded the wingnut between the terminal and the cage once. :eek:
    More wiring
    I used anderson type quick disconnects for the main power. No need to have the winch connected to power 24/7.
    The honeycomb grill on the '11 is great! :D
    Here's how the setup will look while winching. Notice the water resistant covers for the anderson connectors.
    Cleaning up the wiring
    I have to give credit to Colin for this one. He enlarged the mounting hole in the ARB to accept the plug for the remote.
    The start of the remote wiring and the in cab controls. The spade connectors will lead to the ARC relay panel.
    More wiring cleanup
    Here's where the leads for the winch will live. The velcro is just enough to keep the leads from falling out.
    I used the empty parking lot across the street to spool in the wire. I definitely got some looks by passers by. :D
    It was getting dark by the time I finished, but here's the finished shot. I have a daystar hook isolator on the way, so the hook is on the tow point temporarily.
    Now with the daystar winch line isolator.
  5. Mar 24, 2014 at 8:02 AM
    #245
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Wires cleaned up nicely!
    Time for an isolator. it'll keep you from getting a permanant bend in the line at the roller. also keeps you from blowing out your hook on a rock
  6. Mar 24, 2014 at 8:05 AM
    #246
    SMKYTXN
    Nathan
    Houston
    DCFB
    Thanks Colin. I took my time with the wiring. I probably should have stopped for lunch as I was starting to get a little loopy towards the end of the install. :rolleyes:
    Oh, and I'm way ahead of you. :D
  7. Mar 24, 2014 at 8:06 AM
    #247
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Nice!
    and good choice on the Crosby. best of the best!
  8. Mar 24, 2014 at 8:08 AM
    #248
    SMKYTXN
    Nathan
    Houston
    DCFB
    All of my shackles are Crosby. I needed another 4-3/4 ton shackle to go with my kit. I have the 6-1/2 tons on the rear bumper as that's the shackle I use as a go-to for my designs at work.
  9. Mar 24, 2014 at 8:09 AM
    #249
    SMKYTXN
    Nathan
    Houston
    DCFB
    It's a no no to use synthetic on an internally braked winch. Lot's of people do it, but your risking melting the line to the drum. I'll stick with cable for now.
  10. Mar 24, 2014 at 8:09 AM
    #250
    Manwithoutaplan
    ID
    very clean man well done.
  11. Mar 24, 2014 at 8:14 AM
    #251
    SMKYTXN
    Nathan
    Houston
    DCFB
    Thanks bud! Let me know if you have any questions as it sounds like you might be installing a winch sometime in the near future.
    The price point climbs pretty high when you're looking for an externally braked winch. The superwinch line starts around $1600.
  12. Mar 24, 2014 at 8:16 AM
    #252
    Manwithoutaplan
    ID
    I already have winch installed :D.
  13. Mar 24, 2014 at 8:19 AM
    #253
    SMKYTXN
    Nathan
    Houston
    DCFB
    I guess I could have looked at your sig pic to figure that one out. :facepalm:
    So you're going to redo your wiring to the solenoid?
  14. Mar 24, 2014 at 8:25 AM
    #254
    SMKYTXN
    Nathan
    Houston
    DCFB
    Definitely stay away from chains. I have seen chains pop before, not fun. With proper safety precautions, like line dampeners, cable should be just fine.
  15. Mar 24, 2014 at 8:25 AM
    #255
    Manwithoutaplan
    ID
    i think so and maybe make quick jumper cables.
    Because my dumbass always leaves my g/f lights on her car :facepalm:
  16. Mar 24, 2014 at 8:28 AM
    #256
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Winch install looks great!
    One thing you may want to look into it getting some protection for those cables. I got my M8000 for free because the previous owner fried the motor from a short. The short happened right where the motor connects to the cable (see right next to the "A"). Somehow the cable got a hole in it.
    Fried
    This weekend I protected all the wires so hopefully I never have the same issue or burn my truck down.
  17. Mar 24, 2014 at 8:42 AM
    #257
    SMKYTXN
    Nathan
    Houston
    DCFB
    Thanks :thumbsup:
    I'll keep an eye on the cables since they're easy to get too. The welding lead shielding should hold up better than the automotive stereo style wiring though. Good looking out.
  18. Mar 24, 2014 at 8:46 AM
    #258
    XXXX
    sKiP
    05 Prius
    Hell yea it will. The audio rubber is crap compared to welding cable.
    I'm curious as to how the hole started. I think maybe a rock or something at highway speed whacked it.
  19. Mar 24, 2014 at 2:31 PM
    #259
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    OP, are those marine speakers mounted by your radiator?
  20. Mar 24, 2014 at 3:54 PM
    #260
    SMKYTXN
    Nathan
    Houston
    DCFB
    Haha, I'm not that ghetto! No, those are hella supertone horns. They're about as loud as it gets before you go train horns, and they're inexpensive.
