SMKYTXN's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SMKYTXN, Sep 2, 2012.
  1. Jun 22, 2014 at 12:08 PM
    #501
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Thanks bud. It took me quite a while to get it all buttoned up. I've spent at least three weekends working on it. Probably 20 hours. In terms of time spent I didn't save any money, but I wanted to build this myself.
  2. Jun 22, 2014 at 12:10 PM
    #502
    Manwithoutaplan
    ID
    Most of the time DIY project you don't really save that much money.
    I think most of the time it is self gratification if any thing .
  3. Jun 22, 2014 at 12:48 PM
    #503
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    and a better design than just about anything out there. the flat plate ones with turned up edges lack the strength to take a center hit without risk of major bending. all pro's transfer case skid does a slightly better job, but is still doesn't have the strength of something like this.
    Don't know how many hours Nathan has in the finish welding and UHMW work, but it took us an entire day just to get the initial frame cut and tacked up.
  4. Jun 22, 2014 at 12:51 PM
    #504
    skygear
    skygear                    
    who did the pipe relocate?
  5. Jun 22, 2014 at 12:58 PM
    #505
    SMKYTXN
    Nathan
    Houston
    DCFB
    I had a local muffler shop relocate it. We ended up using the stock y-pipe and welded in two new runners. I picked up the header blanket off of Amazon.
  6. Jun 22, 2014 at 1:01 PM
    #506
    skygear
    skygear                    
    what did they charge you for the work?
  7. Jun 22, 2014 at 1:05 PM
    #507
    SMKYTXN
    Nathan
    Houston
    DCFB
    $75
  8. Jun 22, 2014 at 2:52 PM
    #508
    SMKYTXN
    Nathan
    Houston
    DCFB
    Initial layout, cutting, and tacking - 8hrs
    Cutting of infill pieces and drilling holes - 4 hours
    Final welding - 4 hours
    UHMW shaping and painting - 6 hours
    This thing is tough. I lifted the truck nearly off the ground using only one bar.
    If I were to build it again I would have a plate bent for the center section instead of cutting small individual pieces. It would be nice to tuck it up higher but with the use of pipe you can't go any higher without contacting the transfer case.
  9. Jun 22, 2014 at 6:48 PM
    #509
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Usually about $75 -$100.
  10. Jun 26, 2014 at 2:11 PM
    #510
    SMKYTXN
    Nathan
    Houston
    DCFB
    Been daydreaming about building a hauler for the truck, but I think this is the better option. Think the chinook has the range to get me to Moab? :D
  11. Jun 26, 2014 at 2:15 PM
    #511
    Manwithoutaplan
    ID
    that would be bad ass. I but i dont think you can carry your truck like that :p.
  12. Jun 26, 2014 at 2:17 PM
    #512
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'll just build some lift points into the exo cage. No worries!
  13. Jun 26, 2014 at 2:19 PM
    #513
    Manwithoutaplan
    ID
    well then you are good to go.
  14. Jun 26, 2014 at 3:11 PM
    #514
    ckeene9
    Chesterfield, VA
    See Build Thread
    Probably need a few refueling stops. Noisy ass things anyway.
  15. Jun 30, 2014 at 10:07 AM
    #515
    SMKYTXN
    Nathan
    Houston
    DCFB
  16. Jun 30, 2014 at 11:20 AM
    #516
    Manwithoutaplan
    ID
    Very cool picture.
  17. Jun 30, 2014 at 1:57 PM
    #517
    SMKYTXN
    Nathan
    Houston
    DCFB
  18. Jun 30, 2014 at 2:02 PM
    #518
    Manwithoutaplan
    ID
    hope you washed underneath your truck after the dip in the ocean.
    ManBeast likes this.
  19. Jun 30, 2014 at 4:46 PM
    #519
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    First stop we made after airing back up was a DIY pressure wash.
  20. Jun 30, 2014 at 6:59 PM
    #520
    SMKYTXN
    Nathan
    Houston
    DCFB
    The last thing I wanted to do was drive in salt water, but there wasn't any other way to get down there this time. We did hit the trucks with the pressure washer as soon as we came off the beach.
    I plan to get under the truck again when I get to my uncles. I'm headed to Fayetteville AR for the fourth. We're going to run a section of the Trans American Trail while I'm up there. Should be fun.
