SMKYTXN's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SMKYTXN, Sep 2, 2012.
  1. Jul 23, 2014 at 6:20 AM
    #561
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Yeah TXRX is a little lacking on items for working with tubing. The only thing i found there was a old disassemble tube bender at the bottom of a scrap pile.
    Harbor Freight for the win. lol
  2. Jul 23, 2014 at 6:24 AM
    #562
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Well both parts are on their way so I guess I get to be the guinea pig here. The radius of the side of the cab and the roof are pretty large so it shouldn't take too many passes to make the pieces I need. The bed rails will have the same radius as the side of the main hoop. I'll roll one piece and cut all of the rails and the hoop sides from one continuous piece. That's my best bet at getting everything to line up.
    I will probably end up using pre bent tube for the main hoop corners. They'll be sleeved and braced so I'm not worried about not having a continuous tube.
  3. Jul 23, 2014 at 6:29 AM
    #563
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Random question. Tx/Rx is a standard abreviation for transmitter/reciever. that place start out as a radio/electronics lab?
    :popcorn:
    i want to say that the HF roller has notches (for measuring) in the center wheel height guide. if it doesn't, i'd recoment making some. either with some paint, or an engraver of some sort. it'll make repeatable bends a hell of a lot easier. you'll find that the hardest part however, will be getting two consecutive bends in the same plane, just like with the bender i have. so good call on the pre-bents.
  4. Jul 23, 2014 at 6:37 AM
    #564
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    I believe so.
  5. Jul 23, 2014 at 7:02 AM
    #565
    SMKYTXN
    Nathan
    Houston
    DCFB
    The main "lab" has a ton of old electronics gadgets and the president is definitely geared towards the sparky stuff.
    My next trick will be finding 2"x0.120 wall mandrel bends. The site that I found earlier doesn't list mild steel in that size. I've contacted them to see if they have it available, but not listed.
    If that doesn't pan out there is a fab shop north of the office that will do custom bends. I may have them crank out a few 45's, 90's, and 180's for me.
  6. Jul 23, 2014 at 8:08 AM
    #566
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    If you're having a fab/machine shop do it, they may be able to make the bends on a single length in the same plane. cant hurt to ask if they have the capability. even if they don't have a cnc bender, some of the more precise benders can achieve acurate single plane bends when the operator take the time to set everything up
  7. Jul 23, 2014 at 8:10 AM
    #567
    Manwithoutaplan
    ID
    So cray in here.
  8. Jul 23, 2014 at 8:12 AM
    #568
    Manwithoutaplan
    ID
    Btw Colin does your truck ever get tired of doing the same right turn?
  9. Jul 23, 2014 at 8:14 AM
    #569
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's a left turn silly cali boy :p
    still going strong after doing that turn for 4 years straight :D
  10. Jul 23, 2014 at 8:15 AM
    #570
    SMKYTXN
    Nathan
    Houston
    DCFB
    I don't see how they can go from a rolled section, through a 45, back to a rolled section of a different radius and back down again. But it doesn't hurt to ask.
  11. Jul 23, 2014 at 8:17 AM
    #571
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i'll all depend on the proximity of the bends and the capability of their machine/s
  12. Jul 23, 2014 at 8:03 PM
    #572
    SMKYTXN
    Nathan
    Houston
    DCFB
    Made some progress on the model. There's still a lot left to piece together, but it's getting closer.
  13. Jul 23, 2014 at 8:15 PM
    #573
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    That's going to look so bad ass when it's built.
  14. Jul 23, 2014 at 9:07 PM
    #574
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I may have asked this before, but what's the plan for bracing the cab hoop? both vertically and horizontally.
  15. Jul 24, 2014 at 4:10 AM
    #575
    SMKYTXN
    Nathan
    Houston
    DCFB
    We'll see if I can pull it off.
    Definitely need an x-brace from the corners down to the stringers on either side of the box and a horizontal tying the bedsides together. I haven't decided if I'll put a vertical down the middle yet though.
  16. Jul 24, 2014 at 4:52 AM
    #576
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Tube bed is going to be saweet!
  17. Jul 24, 2014 at 5:22 AM
    #577
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i think a straight vertical brace would be a little much for what your truck will initially see with the flatbed.
    when i said horizontal bracing, i menat front to back, not side to side. poor wording on my part.
    like this:
  18. Jul 24, 2014 at 5:41 AM
    #578
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    Let me know if you need extra help when you start the build.
  19. Jul 24, 2014 at 5:43 AM
    #579
    SMKYTXN
    Nathan
    Houston
    DCFB
    More like this Colin.
    I'll definitely do that Phill. Thanks
  20. Jul 24, 2014 at 5:48 AM
    #580
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    very nice :)
