SMKYTXN's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SMKYTXN, Sep 2, 2012.
  1. Feb 1, 2015 at 8:59 PM
    #1021
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Well, I can get pretty close to the measurements I'll need without welding anything onto the truck. I may go with a slightly longer shock than needed so that I don't have to worry about over extension or compression.
    I'm looking at an extended length of 43" or so, but that was just the initial measurement.
  2. Feb 3, 2015 at 1:42 PM
    #1022
    SMKYTXN
    Nathan
    Houston
    DCFB
    Finally put my new wheels on. These are the Konig CounterSteer Type X's.
  3. Feb 3, 2015 at 2:21 PM
    #1023
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    what happend to your sliders?
  4. Feb 3, 2015 at 2:27 PM
    #1024
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    He took them off temporarily because of conflict with the new leaf spring mounting spot.
  5. Feb 3, 2015 at 3:13 PM
    #1025
    SMKYTXN
    Nathan
    Houston
    DCFB
    Yup. I have some DOM tubing headed my way so I can build new rear legs on my sliders.
  6. Feb 3, 2015 at 3:57 PM
    #1026
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    with your new shop toy :spy:
  7. Feb 3, 2015 at 4:34 PM
    #1027
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Damn! Man, thats pretty impressive. Wheels look great btw :cool:
  8. Feb 3, 2015 at 4:58 PM
    #1028
    SMKYTXN
    Nathan
    Houston
    DCFB
    Phill stopped by the shop this evening to help me measure for the new shocks. I took measurements between the underside of the bed and the centerline of the shackle. Here's what I got.
    Compressed = 29.5"
    Extended = 43.75"
    Distance between flat leaf and bump pad = 6"
    Brake lines = 36" (there will be plenty of slack with that length)
    So with adding an inch for forced travel I'm looking at 15.25" of travel in the rear. My plan is to buy a 16" shock and set it so it won't bottom out or over extend. That's the plan anyway.
    With the three other tires on the ground I had 24" under the right passenger tire. The front driver tire had another couple of inches to compress as well.
  9. Feb 3, 2015 at 6:57 PM
    #1029
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    holy flex batman! looks good. hope it all works out
  10. Feb 3, 2015 at 7:00 PM
    #1030
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    Looking good.
  11. Feb 3, 2015 at 8:28 PM
    #1031
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Mmm. Flexy.
  12. Feb 4, 2015 at 5:20 AM
    #1032
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Not needed, but consider an 18'' shock, if you have room to move the shock hoop upward a little. I believe the cost adjustment from a 16 to and 18 is minimal.
    With only 3/4'' "spare" travel on the shock, it will be fairly difficult to have the mounts positioned perfectly as to not bottom or top it out. you're accounting for forced spring flex, which is great because a lot of people miss that extra extension in their calcs with leaf springs. but you also have to account for frame flex. you'll obviously endure more sever forces than what the fork can place on the truck, when you account for extra gear in the truck, inclines, and especially drive train loads to the frame (static and kinetic). if you run bumps at the right height and limit straps, most of these issues go away, but without limit straps, you may be toying on the edge of an overextended shock, having such little room for error.
    just a though :)
  13. Feb 4, 2015 at 5:27 AM
    #1033
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Stop giving him ideas, Colin.
  14. Feb 4, 2015 at 6:59 AM
    #1034
    SMKYTXN
    Nathan
    Houston
    DCFB
    Not a bad idea Colin. The 18" shock has a compressed length of 28" and an extended length of 46". That would give me 1.5" of exposed shaft on compression and an extra 2.25" of extension past my calculated numbers. Definitely provides more room for error on my part. The additional cost to go from the 16" to 18" shock is only $25, so it's kind of a no brainer.
  15. Feb 4, 2015 at 7:00 AM
    #1035
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    $25?! That's precious beer money.
  16. Feb 4, 2015 at 8:30 AM
    #1036
    Tacodriver08
    Tacodriver08 To have faith, is to trust yourself to the water
    Texas
    05 X-Cab 4x4
    Too many to list
    [\QUOTE]03b32907002b31b61963935d55ee2c97_504c081398ac9f40a310b71aa6263c5e4497fb2c.jpg[/QUOTE]
    Looking good Nathan, thats a ton more flex than I though 63's would give you. I would rather go your route than link the rear.
  17. Feb 4, 2015 at 8:35 AM
    #1037
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    Nathan, any issues with the parking brake cable with that much flex? Mine were stretched pretty good at drop after the shackle flip. I'm sure yours drops more than my setup. Just curious.
    Nate
  18. Feb 4, 2015 at 8:42 AM
    #1038
    SMKYTXN
    Nathan
    Houston
    DCFB
    Looking good Nathan, thats a ton more flex than I though 63's would give you. I would rather go your route than link the rear.[/QUOTE]
    There's a lot less math and headache with the 63's than links. You also have a lot more options down the road as far as switching out the leafs and a different axle.
    I checked the cables while it was up in the air. I still had slack in the lines that run down the leafs.
  19. Feb 4, 2015 at 9:57 AM
    #1039
    SMKYTXN
    Nathan
    Houston
    DCFB
    Just ordered my new kings. Looks like a three week build time and then shipping, so I have some time to get a few more projects out of the way.
    King 2.5 Performance Series Smooth Body Shock with Reservoir
    18" travel with piggy back reservoir
  20. Feb 4, 2015 at 11:57 AM
    #1040
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    12/10 jealous right now. What did they cost you, if you don't mind me asking?
