SMKYTXN's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SMKYTXN, Sep 2, 2012.
  1. Nov 10, 2015 at 7:09 AM
    #1541
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    :rolleyes:
    Made that mistake..crazy how the AAL rode rougher than Dakars with D29Xl unloaded..
    Rattletrap66 likes this.
  2. Nov 10, 2015 at 7:39 AM
    #1542
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    don't be jealous o.0
    just have to set them up right. goes beyond just bolting them up.
    if I weren't fixing to cut off the entire rear end of the truck and build from scratch, I'd buy another pair of OEM leafs and an AAL.
  3. Nov 10, 2015 at 8:08 AM
    #1543
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :puke:
  4. Nov 10, 2015 at 8:13 AM
    #1544
    geekhouse23
    Interesting..
    next up for the rear is a shackle flip, greasable shackles and 12" shocks
  5. Nov 10, 2015 at 8:22 AM
    #1545
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    I decided on staying with my 12" shocks since the ride height length of them is 22.5" (4.6" up & 7.2" down), if I go with 14" that will leave me with 1.75" of up travel :eek:
    However, I have a friend who works for 4wheel parts that can get you a set for 66.99/ shock
  6. Nov 10, 2015 at 8:23 AM
    #1546
    geekhouse23
    Well then... :spy:
  7. Nov 10, 2015 at 8:23 AM
    #1547
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    time for a bed cage and some 18s.
    SMKYTXN[OP] likes this.
  8. Nov 10, 2015 at 8:24 AM
    #1548
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    when do you want to get them? I'll see if he can hook you up :D
  9. Nov 10, 2015 at 8:33 AM
    #1549
    geekhouse23
    PM sent..don't want to bore these guys :bananadead:
  10. Nov 11, 2015 at 5:01 AM
    #1550
    cgchambers93
    cgchambers93 Well-Known Member
    Christopher
    Houston
    14 Tacoma SR5 4x4
    Wheels and tires, Billstein suspension
    Would you put the add a leaf in the dakars?
  11. Nov 11, 2015 at 5:02 AM
    #1551
    cgchambers93
    Christopher
    Houston
    14 Tacoma SR5 4x4
    Thinking about going with the 3-4 inch lift 5100s and dakars.
    ragincajun35 likes this.
  12. Nov 11, 2015 at 5:37 AM
    #1552
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    remember to get the extended 5100s that are made for the RCD 4.5'' lift. regular 5100s will be terrible with that much lift.
  13. Nov 13, 2015 at 6:10 AM
    #1553
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    So here's an update on Smokey. Last Friday I went over to the body shop with the intentions of popping the LCA back into place, putting a spacer on, and driving the truck to a friends shop to work on it. Well, I did most of that.
    When I pulled the tire off it was clear that I had an issue. The LCA poppped back into place with the help of the factory bottle jack. It was after getting it back into place that I realized the LCA frame mounts were bent towards the rear of the truck by about 20 degrees. That little Fiat did a number on the truck. The spindle was definitely bent, which I knew, but what I didn't expect was the lower control arm being bent as well.
    I made the decision to let the shop put the truck back to where it was at that point. They straightened the LCA mounts, put an OEM LCA on, and the new spindle I brought them. After all of that they couldn't get the front left to align properly. So it looks like the UCA is damaged as well. It could be just the UCA bolt, or it could be the arm itself. So I made the decision to buy a new set of arms.
    Instead of going back with the SPC LR arms I opted for a set of TC arms. Miles over at @ToyTec Lifts got me set up with a new set of arms and shipped them out yesterday. Thanks again Miles.
    So I'll get the new arms on Monday and have them to the shop on Tuesday. Hopefully that will be the last big purchase I have to make to get the front end back to where it was.
    ckeene9, ERMB and phillstill like this.
  14. Nov 13, 2015 at 7:20 AM
    #1554
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    Not unless you are planning on having a lot of weight on the rear of your truck.... shell, racks, RTT, rear bumper, spare swing out, etc. Flip those shackles though!!!:D
  15. Nov 13, 2015 at 5:09 PM
    #1555
    TacoSTIG
    TacoSTIG Untamed Member
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Just caught up on the build, glad to hear the trucks coming back together stronger than before.
  16. Nov 13, 2015 at 5:35 PM
    #1556
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Uniball lowers or ball joint?
  17. Nov 13, 2015 at 5:42 PM
    #1557
    SMKYTXN
    Nathan
    Houston
    DCFB
    Thanks. She'll be back together soon enough.
    Stock lowers Kase. I want to spend as little as I can on the IFS at this point.
  18. Nov 13, 2015 at 5:43 PM
    #1558
    weldertaco
    texas
    TrailRunner
    Ah I misread. Thought you ordered new lowers! Heard ya on the IFS budget. Solid axle FTW
  19. Nov 13, 2015 at 5:45 PM
    #1559
    SMKYTXN
    Nathan
    Houston
    DCFB
    Yup, uniball TC uppers. Trying to save part of the check for the crawl box. :D
  20. Nov 13, 2015 at 5:46 PM
    #1560
    weldertaco
    texas
    TrailRunner
    :jellydance:
