SMKYTXN's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SMKYTXN, Sep 2, 2012.
  1. Dec 3, 2015 at 12:08 PM
    #1581
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    I could do Texas
  2. Dec 3, 2015 at 12:10 PM
    #1582
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Caaaaarl does Texas.
    Papa Taco[QUOTED] likes this.
  3. Dec 3, 2015 at 12:21 PM
    #1583
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Hush you!
  4. Dec 3, 2015 at 12:26 PM
    #1584
    Papa Taco
    Jared
    Socal
    That's not what I heard
  5. Dec 8, 2015 at 3:41 AM
    #1585
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Did you have any problems running stock sport wheels and 35's?
  6. Dec 8, 2015 at 5:03 AM
    #1586
    SMKYTXN
    Nathan
    Houston
    DCFB
    Not at all. The sport wheels did great, even when aired down to 12psi. The only reason I switched was to go to a wheel with less back spacing.
    Acerwin[QUOTED] likes this.
  7. Dec 8, 2015 at 5:04 AM
    #1587
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    What size spacer did you use? I have the BAMF kit and idk if my rear 1.25" spacers will be enough to clear sport wheels and 35's
  8. Dec 8, 2015 at 5:07 AM
    #1588
    SMKYTXN
    Nathan
    Houston
    DCFB
    I ran the same 1.25" spacers. I still rubbed the frame a bit up front though.
    I'm guessing you'll be fine with the BAMF kit. If not there are always 1.75" spacers. :D
    And if you're going to get a new set of wheels to solve the problem go with a 16". That way you can get down to a 3.5" back spacing.
  9. Dec 8, 2015 at 5:08 AM
    #1589
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Thanks. What all did you cut out/take out from the front to help clear? I've done my CMC far back enough I think
  10. Dec 8, 2015 at 6:24 AM
    #1590
    SMKYTXN
    Nathan
    Houston
    DCFB
    Just the typical stuff. Cab mount, beat the pinch weld back flat, and trimmed 3" out of the fenders. Can't escape trimming the fenders.
  11. Dec 8, 2015 at 6:30 AM
    #1591
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Sweet thanks.
  12. Dec 16, 2015 at 9:13 AM
    #1592
    SMKYTXN
    Nathan
    Houston
    DCFB
  13. Dec 18, 2015 at 2:14 PM
    #1593
    SMKYTXN
    Nathan
    Houston
    DCFB
  14. Dec 18, 2015 at 2:17 PM
    #1594
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  15. Dec 18, 2015 at 2:19 PM
    #1595
    SMKYTXN
    Nathan
    Houston
    DCFB
  16. Dec 18, 2015 at 2:20 PM
    #1596
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  17. Jan 8, 2016 at 7:29 PM
    #1597
    SMKYTXN
    Nathan
    Houston
    DCFB
  18. Jan 15, 2016 at 9:56 AM
    #1598
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Quick question!
    Insurance is cutting me a check to fix my taco and I'll be going flatbed as well finally.
    You have my intrigued with the 63 swap and the beds gonna be off so I figure its the best time to do it.
    Any recommendations that you'd do if you could do it over again? It's all pretty simple with a bit of.welding right?
    Gonna go ahead and cut my frame after the stock shackles as well.
  19. Jan 15, 2016 at 9:57 AM
    #1599
    weldertaco
    texas
    TrailRunner
    And I remember you running procomp 6" lift shocks for a little while as well... Did those match the travel numbers that are recommended for the kit ?
  20. Jan 15, 2016 at 10:09 AM
    #1600
    SMKYTXN
    Nathan
    Houston
    DCFB
    1. Buy the ruffstuff swap kit
    2. Find a set of stock chevy 63 leafs out of the junkyard. The softride leafs have a bit more droop, but twist way too easily.
    3. The bushings in the ruffstuff kit won't fit the leafs, so hit up the parts store for new bushings once you get the bolts and leafs.
    4. Find the right length billstein shock. You'll have to put the kit in and then measure to find your lengths.
    5. The bamf towers may or may not have enough height. You'll probably build your own mounts.
    6. Don't go cutting your frame till you test everything out. The rear mounts will be further back than the stockers.
    7. Measure twice cut once. :D
    Good luck!
    BenMara and Rattletrap66 like this.
