Smog pump noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by typhoon, Nov 14, 2014.
  1. Nov 14, 2014 at 1:53 PM
    typhoon
    typhoon [OP] New Member
    les
    15 tac crew
    I have a 2015 (93 miles) the noise on engine shut down is odd and just not right ,a logical repair would involve a check valve and/or a solenoid valve on the discharge hose. Does anyone know what other car makers do to battle the noise problem?
  2. Nov 14, 2014 at 1:59 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Do you mean it's not right as in somethings wrong, or you don't like it? All the newer trucks, as of 12 I believe, make the smog pump noise. Kind of a clunk suction noise.
  3. Nov 14, 2014 at 2:11 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    it sounds like a pump. its normal, it shuts off after a few seconds.
  4. Nov 14, 2014 at 5:45 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    The 12's smog pumps don't run after shut-off like the 13-up trucks. They run after engine shut down to help evacuate any residual moisture within the pump. Toyota has had bad luck with the smog pumps, especially on the Tundras. I have already had mine in for the smog pump once last winter, I wish mine was programmed to run after shutdown as it would help with future issues.
  5. Nov 14, 2014 at 6:48 PM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    Yes it's 13 and up. Also trucks in these years make a feint sound after you start them up and drive forward about 10 feet. It's the air injection pump.
