Smog pump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DriverSound, Dec 26, 2015.
  1. Jan 3, 2016 at 2:12 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That sounds like the radiator cooling fan clutch to me.
  2. Jan 9, 2016 at 6:33 PM
    ramiroshelby
    ramiroshelby Member
    Ramiro
    Houston
    06 PreRunner SR5
    Well took care of the screeching noise and it turned out to be a worn belt, so now it sounds like a bad pulley but can't tell which one. So next question how would you find out which pulley it is if the serpentine belt controls all of them.
  3. Jan 9, 2016 at 7:53 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    if its making a noise, put a hose as close as you can on each pulley and listen to the other end of it.
    itll help you pin point the noise
  4. Jan 9, 2016 at 8:09 PM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    Put a screwdriver to the pully bolt and listen you'll be able to tell which one is bad
  5. Jan 14, 2016 at 12:54 PM
    ramiroshelby
    ramiroshelby Member
    Ramiro
    Houston
    06 PreRunner SR5
    Well took my truck to the dealership for the recall for the frame rust and found out what pulley was bad. The service adviser would not tell me which pulley that was causing the noise but explained on how much it would cost to replace it. So I kept on bugging him until he told me which pulley it was. Come to find out it was the lower pulley next to the AC compressor. So I ordered a new idler pulley and replaced it today. No more noise.
    What is the normal wear and tear can you put on the serpentine belt. I bought it used with about 30k miles on it. I have 136k on it now. So I am asked how long can you go on the serpentine belt before replacing it. I don't know it it was replaced before I bought the truck or if it is the original serpentine belt.
    Oh I also have a FJ too so I might want to change the serpentine belt so I don't have to replace any other parts. Thank you for your help.
  6. Jan 14, 2016 at 12:57 PM
    scocar
    scocar hypotenoper
    Fuuuu, subbed.
    Looking forward to your follow up.
    Oh, nevermind, looks like it was specific to the 4-banger.
  7. Jan 21, 2016 at 3:42 PM
    DriverSound
    DriverSound [OP] Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Yep, 4 banger for the exhaust issue
  8. Jan 21, 2016 at 3:55 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I don't think I recall seeing serpentine belt replacement in the maintenance manual. Chances are when you bought the truck the belt has not been replaced. 136K miles on the belt is a long time. I would say replacement is between 75-100K mileage. We have 2 other trucks with the 1GRFE both close to or at 100K and belt still looks good.
  9. Mar 1, 2018 at 11:09 AM
    Jbigtoe
    Jbigtoe New Member
    2013 tacoma
    Have Toyota come up with a fix for the smog/air pump nosie
  10. Mar 13, 2018 at 6:06 PM
    Jbigtoe
    Jbigtoe New Member
    2013 tacoma
    Can anyone tell me how to fix the noise from these air/ smogg pumps I have 2013 Toyota Tacoma
  11. Mar 13, 2018 at 6:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Call the dealer and ask if it would be covered for free/warranty
  12. Mar 13, 2018 at 7:20 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    The noise? It’s just a fact of life there is no “fix”.
    Jbigtoe[QUOTED] likes this.
