Smog test failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1998tacoma4x4, Jul 16, 2012.
  1. Aug 22, 2012 at 1:04 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, it's because it's a Cali model.
  2. Aug 23, 2012 at 6:10 AM
    BamaToy1997
    Bill
    Navarre, FL
    I think you have your answer now. I assumed you replaced the front cat, and was not thinking you had two.
  3. Aug 23, 2012 at 12:17 PM
    1998tacoma4x4
    1998tacoma4x4 [OP] Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
    replaced the front cat, still failed the 15mph test. Replaced an o2 sensor and everything passed now.
  4. Aug 23, 2012 at 1:11 PM
    BamaToy1997
    Bill
    Navarre, FL
    Glad to hear it! Those oxygen sensors can be a pain. Did you mention you had replaced/cleaned it at some point? Or was I thinking of another post from someone in another thread.
  5. Aug 23, 2012 at 5:05 PM
    1998tacoma4x4
    Orange County
    Someone had mentioned if i checked my o2 sensors previously, but i said i wasn't sure of their condition because my cel was off.
  6. Aug 24, 2012 at 10:22 AM
    BamaToy1997
    Bill
    Navarre, FL
    Yeah, always want to check them for accuracy. The CEL will only come on if the sensors does not show crossovers, or the voltages get too extreme. Smaller errors which will not set a code, but will fail smog tests are not uncommon. Congrats on getting it to pass!!
  7. Nov 19, 2013 at 2:14 AM
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    a cheap guess would be clean mass air flow sensor with mass air flow cleaner and cross you r fingers. cheap guess without alot of info,also I hate stuff like this but I have heard there is some stupid fuel additive that brags about passing smog guarantee. usually it seems its 02 sensors or mass air flow sensor.
  8. Nov 19, 2013 at 8:46 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    Since the OP passed his emissions inspection 16 months ago, your insightful tips probably will fall on deaf ears.
  9. Nov 19, 2013 at 8:47 AM
    Moco
    Eric
    NoVA
    Since we are on the topic, can someone knowledgable on the matter post how to check O2 sensors when they are not lighting a CEL. How can you verfiy if they are functioning properly if they are not crossing the threshold to light the CEL?
  10. Nov 19, 2013 at 9:03 AM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    A good technician with a scan tool can see live data from the o2 sensors and it is based on the sensors reaction speed and min/max voltage output, they get slower over time and cause these problems with out throwing a code.
  11. Apr 17, 2014 at 10:38 AM
    blazintowers
    blazintowers Member
    todd
    Saugus, SOCAL
    97 tacoma 4x4, 5spd manual, 31.5"M/T
    Hi taco lovers, me too. I have a 97 tacoma with 250,000 miles yeah! bought it used a couple of years ago and when I had to smog it then it barely passed he HC emissions at 15mph test. now two yeasrs later it failed the HC at the 15mph and barely passed at the 25mph. everything else seems normal. I have changed plugs, wires, pvc, fuel flter, air filter, oil change, and then retested with a little race fuel and using that CRC stuff, but still failed! tester said the catalytic needs to be replaced? should I try the O2 snsors first? dont know if they have ever been replaced? I can post the last three test sheets if that helps? Thanks for any of your responses in advance....fron just some old dude trying to remedy the issue without paying through the roof! thanks again!
  12. Apr 17, 2014 at 1:10 PM
    SDSam
    San Diego
    00 Tacoma prerunner
    Tech is mostly right with it being the cats as in there are 2ea. my 2000 will need them next test as they where showing weakness on the test.
    They don't maintain operating temperatures on the 15mph part of the test and fail.
  13. Apr 17, 2014 at 2:37 PM
    blazintowers
    blazintowers Member
    todd
    Saugus, SOCAL
    thanks SDSam, do you know how to tell if they are maintain temp? do you know how hot they should be running? I only see one cat on my 97? I will check again to see if I missed one somewhere. thanks again!
