Smogging in Cali
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stitch925, Dec 31, 2021.
  1. Dec 31, 2021 at 9:09 AM
    Stitch925
    Stitch925 [OP] New Member
    Lyle
    Berry
    I have a 2nd GEN Tacoma going to install pedal commander but live in Cali was wondering about sniffing do I just unplug it and will my Tacoma automatically go back to factory settings wondering be I install it
  2. Dec 31, 2021 at 9:28 AM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    I didn't know the Colombians require a smog check.
  3. Dec 31, 2021 at 9:32 AM
    Stitch925
    Lyle
    Berry
    California (Califucinus)
  4. Dec 31, 2021 at 9:59 AM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Does it have a CARB EO number? If not, and the tech sees it or it shows up, he will flag it. If you pull it, make sure you do it a bit ahead of time, if it creates any type of reset in the ECU, that has to be, I think, a certain amount of miles old or it flags. You might go and talk to a smog guy to get an expert opinion on how and if it will create a problem and how to side step it. The guy I have used has tested my old rig off the reporting system to check out something for me.
    Any fail also reports up to the state and is recorded on CARFAX, which can affect resale. Multiple fails can cause the state to declare the vehicle a “gross polluter” which can create some additional problems.
    That being said, I ran a pretty aggressive tune on my last truck and when I built a new engine for it, it had some non smog internals along with some EO numbered stuff. It ran cleaner than it did stock with no electronic flags and no externals that were problematic.
    Basically, you want to know if it will pass visual inspection and the electronic feel-up. I doubt the Commander will change the emissions as they are taken at a steady RPM.
    Taco 422 likes this.
  5. Dec 31, 2021 at 10:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If it's not seen, you will pass just fine. Pedal commander does nothing to the ECU.
    Also the smog test will not have a sniffer portion as you are newer that a model year 2000
    whatstcp likes this.
  6. Dec 31, 2021 at 10:13 AM
    eon_blue
    Azusa, CA
    Yeah you don't have to worry about a sniff test unless your vehicle is older than 2000. Just a OBDII check for trouble codes and a visual inspection. What they don't see won't hurt you. I've had a non-CARB compliant URD 7th injector kit installed on my truck for 6 years now and have passed smog with it 3 times. They just don't know it's there. Or maybe they do and don't care, who knows. I always go to the same guy though just to be safe lol.
  7. Dec 31, 2021 at 10:42 AM
    Stitch925
    Lyle
    Berry
    So thanks everyone next question so when that smog time comes should the pedal commander be at certain setting
  8. Dec 31, 2021 at 10:50 AM
    nd4spdbh
    SoCal
    Again, the pedal commander does nothing to the ECU so as long as you don't have a check engine light you will be fine
  9. Dec 31, 2021 at 3:19 PM
    nd4spdbh
    SoCal
    if you are so worried, simply unplug it and remove it from the vehicle. Technically its not tampering with any emissions components or modifying the ecu so even if it was seen on a visual it wouldn't fail you (if that tech knows the bounds of his inspection)
  10. Dec 31, 2021 at 4:20 PM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    With OBDII no sniff is correct, but, they are now looking for third party tunes (which in your case is not) via scan so be sure you don't have or at least put back to stock and do the drive thing prior to having it checked.
