smoke at start up till warmed up
Discussion in '1st Gen. Tacomas (1995-2004)' started by westhumboldt, Dec 29, 2015.
  1. Dec 29, 2015 at 3:12 PM
    westhumboldt
    westhumboldt [OP] Well-Known Member
    Arcata,Ca
    97 Tacoma sc 4x4
    Doug Thorley headers, urd 7th and Trd Supercharger, bilstein lift, trd locker just installed.
    My truck smokes a good bit until warmed up. I Its not mixing oil or coolant. I don't think it is moisture in the exhaust. Anybody have thoughts on what it is diagnosing it?
  2. Dec 29, 2015 at 3:16 PM
    westhumboldt
    Arcata,Ca
    97 Tacoma sc 4x4
    It is white and does not dissipate quickly, after about 5 minutes.
  3. Dec 29, 2015 at 3:18 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    Its cold here now so I would consider that normal. Unless as mention there is a smell from the fume
  4. Dec 29, 2015 at 3:18 PM
    Indy
    Indy Master of all I survey.
    Bad head/gasket. Parts swell as they heat up and close the leak, shrink when they're cool and allow the leak.
    But 'a good bit' is hard to quantify. And how 'cold' is cold? FWIW it's 18 degrees here, no smoke out of my pipe.
  5. Dec 29, 2015 at 3:19 PM
    westhumboldt
    Arcata,Ca
    97 Tacoma sc 4x4
    It is just smoking a lot more then usual.
  6. Dec 29, 2015 at 3:20 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sounds like a head gasket to me. Go get a leakdown test and make sure they do it when the engine is completely cold and again warned up. That's is generally a solid way to prove it.
  7. Dec 29, 2015 at 3:20 PM
    westhumboldt
    Arcata,Ca
    97 Tacoma sc 4x4
    If a bad head gasket wouldn't the fluids be mixing?
  8. Dec 29, 2015 at 3:21 PM
    Speedytech7
    Not necessarily, head gasket can break many different ways. Between cyls, water jacket to cyl, water jacket to oil gallery, oil to cyl... Many ways to break
  9. Dec 29, 2015 at 3:21 PM
    westhumboldt
    Arcata,Ca
    97 Tacoma sc 4x4
    I have had a leak down test about 1000 miles ago all cylinders are great. I will let it cool and start it up and smell the exhaust.
  10. Dec 29, 2015 at 3:23 PM
    Speedytech7
    Did you have a leakdown or a pressure test. They are very different. You could also have the coolant checked for the presence of combustion gasses.
  11. Dec 29, 2015 at 3:24 PM
    westhumboldt
    Arcata,Ca
    97 Tacoma sc 4x4
    Whats the difference between the two?
  12. Dec 29, 2015 at 3:26 PM
    Speedytech7
    Leakdown tests where the cylinder is leaking to by pressurizing it with compressed air and listening for the leak in various areas like exhaust pipe, oil cap, radiator, etc. Compression test just checks instant pressure during a cranking sequence not necessarily how well the cylinder can hold pressure.
  13. Dec 29, 2015 at 3:28 PM
    westhumboldt
    Arcata,Ca
    97 Tacoma sc 4x4
    ooo i had a compression test
  14. Dec 29, 2015 at 3:30 PM
    Speedytech7
    Sorta figured (it's more common for people to mention), that's why I asked. Compression test won't really tell much other than if you engine is super worn out.
  15. Dec 29, 2015 at 3:31 PM
    Speedytech7
    Leakdown is what determined my head gasket had taken a dump. Cost me $150 for the shop to do the test after I left my truck there all night.
  16. Dec 29, 2015 at 3:31 PM
    westhumboldt
    Arcata,Ca
    97 Tacoma sc 4x4
    So is getting a leak down test the proper route to see if it is the head gasket?
  17. Dec 29, 2015 at 3:33 PM
    Speedytech7
    It's one of the ways, other would be to check for combustion gasses in radiator but it's not as definite. Leakdown can determine if other things are worn too.
  18. Dec 29, 2015 at 3:35 PM
    Speedytech7
    Could be right, I wish mine was
  19. Dec 29, 2015 at 3:37 PM
    westhumboldt
    Arcata,Ca
    97 Tacoma sc 4x4
    the exhaust does smell sweet. So must be head gasket.
  20. Dec 29, 2015 at 3:38 PM
    Speedytech7
    Lol how bout a can of ether and a bendy straw?
