Smoke on Start-up (Advice Please)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco.VR4, Mar 11, 2012.
  1. Mar 11, 2012 at 3:23 PM
    Taco.VR4
    Taco.VR4 [OP] Fast Cars, Off-Road Trucks, and Hott Women ;)
    Jay
    Grand Rapids, MI
    '02 Tacoma, '97 3000GT
    5100s, Icon 3 AAL, Custom-built front/rear bumpers, Hybrid seats, 3000GT modified intake box, toolbox, D-rings
    So I just recently noticed that the taco hick-ups a little occasionally on start-ups and blows some blue smoke. I know the textbook answer (piston rings) but at the same time bad piston rings tend to have a correlation to how long its sat without running... Mine doesn't seam to have any direct relationship of quantity of smoke to length of sitting.
    it did recently throw a Bad Front O2 sensor code...
    Any ideas???
    And just to spruce this thread up a bit:
  2. Mar 11, 2012 at 4:57 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    Jay try cleaning you MAF first. The environment we wheel in has made me have to clean mine more than once.
  3. Mar 11, 2012 at 9:56 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    ^The MAF sensor doesn't cause Blue smoke to come out of his engine lol... You guys and you're MAF.
    My clutch is burning? Try cleaning your MAF sensor!
    My A/C isn't blowing cold? Try cleaning your MAF sensor!
    My truck's 4WD doesn't engage? Try cleaning your MAF sensor!
    My truck wobbles at 60 mph? Try cleaning your MAF sensor!
    My horn goes off by itself? Try cleaning your MAF sensor!
  4. Mar 11, 2012 at 9:59 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Cuz it works:D
  5. Mar 11, 2012 at 10:05 PM
    broken taco
    broken taco Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
    yea. mine did that once acouple of weeks ago but hasnt done it since. so im hoping im fine....:eek:
  6. Mar 11, 2012 at 10:09 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Smoke on startup is valve guides.
    Rings would be if you get on the gas and it blows blue.
  7. Mar 11, 2012 at 10:10 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    valve guide SEALS.
  8. Mar 12, 2012 at 12:14 AM
    tacobo670
    Ray
    Las Vegas
    that dont look too bad. just as long as its not a constant stream of blue smoke, or if it gets worse when u accel. if its just that one puff on start up, i dont think its nothing to be too concerned about at this time.
  9. Mar 12, 2012 at 12:15 AM
    tacobo670
    Ray
    Las Vegas
    idk, may even be the type of oil ur using. if too thin or to much "super-lube-cleaning-agent-additive" in oil, it may just be seeping by the seals.
  10. Mar 12, 2012 at 3:36 AM
    atvlifestyle
    Michigan
    01 trd tacoma
    Quick to criticize but no helpfull advice.
    Anyways first rule of wrenching yourself is to start with the simplest things. And yes with the winter mixture of gas around here and sand particles on my MAF I have had all kinds of funny colored smoke come from my truck. And cleaning it fixed it. Damn electronic controlled vehicles these days.
  11. Mar 12, 2012 at 5:25 AM
    Taco.VR4
    Jay
    Grand Rapids, MI
    Well mine usually just stutters when I start it up but yesterday it stuttered to the point of stalling so its getting worse...
    I have done VSS (Valve stem seals) on the 3000gt before and it was probably the hardest job i have done to date on a vehicle lol... anyone have any experience doing them on a taco?
    And Chris I'll clean the MAF just in case... I think I'm also gonna pull that O2 sensor that threw the code and try cleaning it
  12. Mar 12, 2012 at 5:46 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You might pull a valve cover and make sure it's not all yucked up with sludge but every one that said valve seals/ guides are spot on however if the oil can't get back into the sump it will smoke on start up also no matter how good the seals are.
  13. Mar 12, 2012 at 5:57 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Wow no wonder the chemical co's are so profitable save your self some effort go buy a new O2 sensor.
