Smoke on start up on NEW 2010 4.0 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toobold, Mar 17, 2010.
  1. Mar 17, 2010 at 6:47 AM
    Toobold
    Toobold [OP] Active Member
    Hello everyone. I just purchased a new 4x4 DB-cab Tacoma with the 4.0. I only have 248 miles on this truck. Yesterday I started my truck up after it had sat for the past 4 days and it put out a puff or white smoke on start up. Please dont tell me I have a lemon. Any input would be greatly apprciated. I am hoping this will stop after the break in period...HELP
  2. Mar 17, 2010 at 6:49 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Where was the smoke coming from???
    Oh and welcome to TW
    :wave:
  3. Mar 17, 2010 at 6:53 AM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    probably water vapor. but why ask us? take it to the dealer. you should still be under warranty;)
    Welcome to TW!
  4. Mar 17, 2010 at 7:08 AM
    Toobold
    It was coming from the exhaust outlet. I know it wasnt vapor..its was a white smoke. Thanks for the quick reply..
  5. Mar 17, 2010 at 7:26 AM
    Bart
    Bart Well-Known Member
    Franklin,NC
    08 TRD OFFROAD V6 4x4
    metra ipod
    Mine did the same thing and still does sometimes I think it's just the truck I have 63k on it and no motor problems.
  6. Mar 17, 2010 at 7:27 AM
    WestonJ
    WestonJ Well-Known Member
    Weston
    Corpus Christi, Texas
    2010 Access Cab TRD Off-Road 4WD
    Added a Tool Box, rear spring TSB, Weathertech floor mats, Emergency lights,
    my 2010 tacoma does the same thing. when i start it on a cold morning and drive down the road, alot of white smoke or vapor comes out of the exhaust, but then the engine warms up and it goes away. my 2001 tundra did the same thing
  7. Mar 17, 2010 at 7:30 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    head gasket.... :D IDK :popcorn:
  8. Mar 17, 2010 at 7:36 AM
    bigburrito
    DuPage County
    '09 TRD OR
    maybe the taco is dread! :rasta:
  9. Mar 17, 2010 at 8:55 AM
    Bgarner
    Bgarner New Member
    Brandon
    GA
    Tacoma Prerunner DC
    I have a 2010 and mine did the same thing for about 500 miles. worried me too but it went away.
  10. Mar 17, 2010 at 8:56 AM
    dgr540
    dgr540 I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    I have had mine not want to start on me a few times now. Mine is 09 with 8k on it.
  11. Mar 17, 2010 at 9:20 AM
    xpdishun
    xpdishun Active Member
    10 AC SR5 4x4 6MT V6
    White smoke might just be water vapor or unreacted exhaust. Blue smoke is oil and what you need to worry about. Next time you start your truck, check what color the smoke is. Here are two common causes of both colors smoke on a new vehicle.
    When you first start the car, the cat is not warm and doesn't allow all the exhaust to react as it should before leaving the tailpipe. This is exacerbated in the winter with the cold ambient temperature. This creates the white smoke. Don't worry about it, it just happens and it won't hurt anything in your truck.
    I can't say this is the case of the Toyota engines but some of the older Honda VTEC engines (think Prelude) had an issue where oil would build up in the complex valve train after letting the car sit. Some of the gaskets for the VTEC components would shrink as the engine cooled and let some of that oil trickle into the cylinders, but only a minute amount. When you next start up the engine, the oil will burn off in the first few minutes. This also isn't really a problem but it's good to keep an eye on it. I haven't heard of this being an issue with our engine so I'd be surprised if it was the case. I'd bet the cold cat is your problem.
  12. Mar 17, 2010 at 9:41 AM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    Give the piston rings a chance to seat completely, about 3000 miles
  13. Mar 17, 2010 at 9:55 AM
    09TRD
    09TRD it is what it is
    Oakwood GA
    09 TRD Off Road
    Not yet,
    Mine does the same thing when it sits for a a few days...... always has
  14. Mar 17, 2010 at 10:08 AM
    grammy
    grammy Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    Normal
  15. Mar 17, 2010 at 10:26 AM
    Country
    Country Well-Known Member
    Country
    East Texas
    2010 Dbl.-Everyone says it looks like a tank
    Pro Comp 6in lift w/ Icon Coilovers,AllPro UCA's, AllPro Baja Leaf pack, Bilstein 5150's in the rear. Tires Mickey Thompson MTZ 275/70R18 w/ procomp 7089 wheels. ARB front bumper with mile marker winch, Custom made all quarter inch steel rear bumper. Demello rock crusher slider's. CoverKing neoprene seat cover's, AllPro trail armor All-pro U-bolt flip kit with Timbren bump stops and many many many other mods, way to many to list.
    U are defineltly still under warranty, but prolly water vapor or some bad gas with water in
  16. Mar 17, 2010 at 12:04 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Jesus, next thing you know, you'll tell us your engine makes a noise when you turn it on.
  17. Mar 17, 2010 at 1:54 PM
    pcool69
    pcool69 Member
    Cypress, TX
    11 F150 SuperCrew Lariat
    I get the white exhaust as well with 325 miles on the truck. I would bet that it will be gone by the first oil change.
  18. Mar 17, 2010 at 3:53 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    I was always taught that white smoke is vapor and blue smoke is oil. However, my R1150GS air cooled motorbike puts out white smoke every now and then and most of the time in the morning -- it's definitly not vapor. It burned a modest amount of oil till I wreked it at 88k miles
    The piston rings may have not seated or who knows what it was. Again the bike worked Like a champ and compression on both cilinders what on the high end of the mfg specs.
    Keep an eye on the oil till you know if it consumes oil or not. Remember just because it consumes a little oil doesn't = bad engine
  19. Mar 17, 2010 at 4:51 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Normal operation and more noticeable on newer vehicles.
  20. Mar 17, 2010 at 4:54 PM
    jmcwms
    jmcwms Lazy, Good For Nothin'
    James
    Central Louisiana
    07 4x4 DC
    What he said.
    My 07 still does it on cool mornings.
