Smoke on startup only
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dbrawner, Nov 5, 2019.
  1. Nov 5, 2019 at 11:28 AM
    #41
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    No reason a 2016 shouldn't be mechanically perfect. Especially when there's so many of them sitting out there on lots and in private listings. If it was a 10 or 20 year old purchase I'd agree with you. But that's too new, too big of a purchase to settle for less than perfection unless OP got some comically good deal on it. I would not feel good about long term owning a 3 year old truck that needed to go in for engine work.
    Forums are about aggregating opinions. OP can take mine and yours and form his own conclusions.
  2. Nov 5, 2019 at 11:29 AM
    #42
    dbrawner
    dbrawner [OP] Member
    2016 Tacoma TSS 4x4
    This is reassuring. Everything looks like it's in great shape. Hopefully I can find a mechanic that can change these seals in the manner you stated earlier.
    I have no intention of "dumping" the truck. I'm really enjoying this truck and want to keep it.
  3. Nov 5, 2019 at 11:30 AM
    #43
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    well, if you ask random people expect random answers. Also a car like will run like that for as long as you check and change the oil... cats and o2 sensors will need more attention.
    GreyBaldTaco likes this.
  4. Nov 5, 2019 at 11:30 AM
    #44
    eon_blue
    Azusa, CA
    People saying head gasket...doesn't a bad head gasket usually result in white smoke from burning coolant? White and sweet smelling? I was under the impression blue smoke was burning oil which could be a number of different things, but not a head gasket
    BassAckwards likes this.
  5. Nov 5, 2019 at 11:32 AM
    #45
    MaynardVanZant
    MaynardVanZant No.
    Alaska
    2017 DCSB TRD OR MT
    MBRP Catback 2” Bilstein 5100 lift
    Who doesn’t check their oil? And jfc, leaky valve stem seals aren’t going to foul your o2 sensors or cats. We aren’t talking about piston rings that got shot out the tailpipe after a 9k pull down the strip.
  6. Nov 5, 2019 at 11:35 AM
    #46
    auskip07
    Skip
    Atlanta, Ga
    The same people that dont do their own oil and trade their cars in every 3 years. I would argue they will foul quicker than those not leaking.
    MoneyMan55, GreyBaldTaco and na8rboy like this.
  7. Nov 5, 2019 at 11:35 AM
    #47
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If this is valve stem seals, it's not a complicated fix and it's not a chronic problem. Get it fixed and you're in business. If the dealer is willing to play ball on a repair, take them up on it, but don't try the Lucas product - that is a bandaid at best.
    Chew, TRDNoPro, Boghog1 and 3 others like this.
  8. Nov 5, 2019 at 11:37 AM
    #48
    MaynardVanZant
    MaynardVanZant No.
    Alaska
    2017 DCSB TRD OR MT
    This guy gets it. The OP knows what to do. /thread
  9. Nov 5, 2019 at 11:37 AM
    #49
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I concur rings or head gasket , possibly valve stem seals on the intake side since the smoke has a blueish tint to it. Ugh!!!
  10. Nov 5, 2019 at 11:38 AM
    #50
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    pulling the plugs will identify the offending (floor mat, propshaft, trans buckle, fiddle stick, affected cylinder)
    good luck, bring a kitten with you :D
  11. Nov 5, 2019 at 11:39 AM
    #51
    MaynardVanZant
    MaynardVanZant No.
    Alaska
    2017 DCSB TRD OR MT
    I think it’s the retrofitted reciprocating dingle arm attached to the anti lag turbo encabulator .
    MikeyD.25, GreyBaldTaco and DETaco17 like this.
  12. Nov 5, 2019 at 11:40 AM
    #52
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    those friggin dingle arms will get ya....
    MikeyD.25 likes this.
  13. Nov 5, 2019 at 11:41 AM
    #53
    0xDEADBEEF
    MikeyD.25 and 127.0.0.1[QUOTED] like this.
  14. Nov 5, 2019 at 11:45 AM
    #54
    MaynardVanZant
    MaynardVanZant No.
    Alaska
    2017 DCSB TRD OR MT
    Crap. In all the years I’ve been wrenching on things for money, I never asked Mr. mechanical object what was wrong with it... in its own opinion.
    “I feel like you just don’t understand me.”- Valve stem seal.
  15. Nov 5, 2019 at 11:50 AM
    #55
    GrittyTaco
    GrittyTaco Well-Known Member
    Hatboro, pa
    2017 dclb trd or
    Was this a certified truck ? If so Toyota’s power train warranty is 7 year 100k so this should be covered if it is. ( bought my taco a few months ago and when I did Toyota had just changed their policy to this )
    MoneyMan55 likes this.
  16. Nov 5, 2019 at 11:51 AM
    #56
    dbrawner
    2016 Tacoma TSS 4x4
    I'm not sure. I didn't buy it from a Toyota dealership? How would I find out?
  17. Nov 5, 2019 at 11:54 AM
    #57
    ryan760
    ryan760 Well-Known Member
    You can call up any Toyota dealer and give them your VIN. They should be able to look up your warranty info. My guess is that you are out of warranty, and the previous owner dumped his problem truck on you.
  18. Nov 5, 2019 at 11:54 AM
    #58
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    That's why I enjoy some of these threads so much! Some of the "diagnosis" and "suggestions" people throw out there are crazy. :facepalm:
  19. Nov 5, 2019 at 11:57 AM
    #59
    Tacospike
    Two Trucks
    Some are creative though.
  20. Nov 5, 2019 at 12:12 PM
    #60
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Add a can of Motor Honey and you're good to go. :thumbsup:
    Hobbs likes this.
