Smoke on startup only
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dbrawner, Nov 5, 2019.
  1. Nov 5, 2019 at 1:37 PM
    #81
    btcca4
    btcca4 Well-Known Member
    Picture of the exhaust tip?
    Italian tune-up could not hurt..
  2. Nov 5, 2019 at 1:51 PM
    #82
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Blue smoke no bueno sad to say.
    I’m guessing maybe oil maybe getting past the valve seals, or oil return passages may have gunk or oil viscosity is wrong and not flowing/returning to the sump as it should.
    Lot of many other maybe’s so I’d start with the basics, an oil change and analysis, replace the pcv valve because I’m assuming it’s starts (quickly) as it should, not missing with plenty of power thereby maybe eliminating bad rings.
    Best of luck
  3. Nov 5, 2019 at 1:57 PM
    #83
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Sorry about that OP. That's definitely Blue and IS a problem.
    G.
  4. Nov 5, 2019 at 2:29 PM
    #84
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    No warranty?
  5. Nov 5, 2019 at 2:47 PM
    #85
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    ah, good point! Ive only ever seen lighter smoke from headgaskets, i guess all of the audis ive dealt with leaked so much oil that they just made clouds from the oil.
  6. Nov 5, 2019 at 2:49 PM
    #86
    The hammer
  7. Nov 5, 2019 at 3:06 PM
    #87
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    This case is why I do not buy used cars... I would have a nerve breakdown if this happened to me...
    OP I truly hope that you can fix your truck and do t loose too much money..
  8. Nov 5, 2019 at 3:16 PM
    #88
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    agree..
  9. Nov 5, 2019 at 3:18 PM
    #89
    kahanabob
    Maui
    16 TRD 2WD 4DR
    yea, power train warranty. what is the max miles for that?
  10. Nov 5, 2019 at 3:23 PM
    #90
    LoveableWerewolf
    Nashville
    The more I learn, the more wary about that. A new car you can keep a long time and know everything that has happened to it.
    The hammer likes this.
  11. Nov 5, 2019 at 3:31 PM
    #91
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    60k
  12. Nov 5, 2019 at 3:33 PM
    #92
    The hammer
    I'm gonna take a wild guess that you're not a big gambler...
  13. Nov 5, 2019 at 3:37 PM
    #93
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Im assuming you have never owned a vehicle past 170k, Done road side fixes to get it started, not overheating etc. Hasnt everyone pissed in a radiator?
    he can still drive his truck and deal with it.... its not like his wheel fell off.
    rmac010 likes this.
  14. Nov 5, 2019 at 3:42 PM
    #94
    rmac010
    rmac010 Well-Known Member
    2017 DCSB TRD Sport
    Hopefully the OP got a good deal & has some $$$ set aside to fix the truck.
  15. Nov 5, 2019 at 3:43 PM
    #95
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Between my parents, sister and I, we've bought 1 new car in the last 45 years, out of about 12 of them. On the whole, the only one that really sucked was a 94 Ford Thunderbird. The rest have been fine. If you do your research, you can save a lot of money buying used.
    fiftyxp and rmac010 like this.
  16. Nov 5, 2019 at 3:45 PM
    #96
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    drive it and check the oil level weekly. Probably not an issue. I previously owned two 2nd gen’s with the same issue. No issue than occassional puff at cold startup. I put 400K miles on them with occasional start up puffs
    rmac010 likes this.
  17. Nov 5, 2019 at 3:48 PM
    #97
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    OP, did you ever get a professional opinion on the root cause of the problem?
    Chew likes this.
  18. Nov 5, 2019 at 3:53 PM
    #98
    The hammer
    A professional opinion would cost mucho dinero $$$$ and I'm guessing he bought used to save some.
  19. Nov 5, 2019 at 4:04 PM
    #99
    dbrawner
    dbrawner [OP] Member
    2016 Tacoma TSS 4x4
    Wow guys, this really blew up. Thank you all very much for taking the time to respond and help me figure this out.
    I've talked with two different mechanics in my area. The mechanic at the place I bought it told me to continue to check the oil and coolant levels until I'm due for an oil change and they would do the next oil change and would add Lucas (which I really don't want to do) and if that didn't help, they would look at the valve stem seals and go from there. They are willing to help me since I bought it there, which is hard to pass up.
    I got another opinion from a trusted mechanic that I've used before. He said that they may have put a different weight oil than 0w20 and the different viscosity could be cause oil to leak and past and burn up upon starting. He said as long as my oil and coolant levels were good, the truck wouldn't be affected and that the smoke was more of a nuisance than a mechanical issue. He said he would let the other place do the oil change at 80k miles and go from there since they are willing to help.
    I've put 1,500 miles on it in two weeks and I can't tell that the oil or the coolant has dropped any at all. I think I'm going to change the oil this weekend and put the recommended oil just for peace of mind.
    shakerhood, BSFord and 0xDEADBEEF like this.
  20. Nov 5, 2019 at 4:09 PM
    #100
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    I dont like either of these ideas just fyi
    Chew likes this.
