Smoked badges experiment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by azchris, Jun 19, 2011.
  1. Jun 19, 2011 at 8:19 PM
    azchris
    azchris [OP] Well-Known Member
    Phoenix
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    Looking at all the Plastidipped emblems gave me an idea, but since I hate flat black (and Plastidip - sorry :D ) I wanted to kind of make them darker without losing the shiny-ness.
    I took a trip to my local O'Reilley's and found some interesting stuff by Duplicolor called "Shadow" that is supposed to give chrome-like surfaces a tinted effect while still being durable enough to use on trim and wheels. I picked up the Shadow, clear coat, and adhesion promoter for about $25.
    Now onto the pictures:
    What I used
    Duplicolor Shadow kit, Duplicolor Adhesion Promoter, Grip Solvent (the key to debadging in 30 seconds with no hair dryer ;) ), Goo Gone to clean up the rest of the adhesive, and some fishing wire for the debadging. Finally, 3M Nameplate Repair tape and a razor blade to cut it.
    Step 1
    Since I'm not sure how this is gonna turn out, I'm only doing the PreRunner badge today. If it looks like crap, I'll take the V6 off and throw them both away! Masked off the badge so I know where to put it back on.
    Step 2
    Pour some solvent down the back of the badge, wait about 30 seconds for it to soak in, and slice the badge right off with fishing wire.
    Step 3
    Removed excess tape from the truck with Goo Gone and my finger.
    Step 4
    Did one light and one thick coat of adhesion promoter, then waited about 10 minutes. Laid on one light coat, and one thick coat of the Shadow waiting about 10 minutes in between each coat. The can recommends 20 minutes, but since this is Arizona in the summer, paint dries about twice as fast :D
    Step 5
    The paint needs to dry, and it's 100 degrees outside. Run errands in air conditioned truck and pick up a large Dr. Pepper from BK on the way back.
    Note that in order to bond properly, the clear coat needs to be applied within 20 minutes to an hour after the last coat of paint. Hurry home.
    Step 6
    Three coats of clear, waiting 10 minutes in between. Make the last one nice and thick. Set it inside the garage to dry and go out to dinner.
    Step 7
    Put your pictures up on TW after dinner so everyone can criticize my idea. Decide that it needs another layer of clear coat, which I'll put on in a day or two once the paint has cured. This gives you a couple days to decide whether or not you want to do the rest of the badges the same way.
    Step 8
    I waited overnight and applied a final, thick coat of clear the next day. Let that dry for a few hours.
    Step 9
    Put a bunch of 3M tape on the back of the badges, I think this is the most time consuming part of the whole process.
    Results
    So far I like it. It's not quite as black in person, it actually matches the smoked out reverse light/turn signal pretty well (if you have the 09+ tails). After it cures for a couple days I'll see how it holds up on the truck :D
  2. Jun 19, 2011 at 8:56 PM
    BenWA
    BenWA Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
  3. Jun 19, 2011 at 9:06 PM
    GatorComa
    GatorComa Well-Known Member
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    sub'd. I like this idea...I want to see how it looks on the truck and with the other badges done too if you do them, I think I might have to try this. Looks good :thumbsup:
  4. Jun 19, 2011 at 9:07 PM
    azchris
    Phoenix
  5. Jun 20, 2011 at 7:10 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    So, did the Smoke go on non-splotchy? In your Step 4 pic it looks a bit splotchy. I'd tried something like this some time ago with some modelling black chrome paint and could not get it to go on and spread out nicely, SPLOTCHY. Step 4 pic looks a bit like what I experienced, but your end pic looks smooth. Was there any splotchy look in the end on your's?
  6. Jun 20, 2011 at 7:24 AM
    LaTechLogan
    LaTechLogan Well-Known Member
    Logan
    Louisiana
    '08 PreRunner Sport
    - K&N intake - Pioneer headunit - 2 Kicker 10" subwoofers & amp - Nokya Hyper Yellow foglights - 18" Magnaflow muffler - Bilstein 5100 shocks set to 0" - Eibach coil springs - 1.5" blocks in back
    I love this idea, but when I tried it with my front emblem it didn't turn out like I would have liked. I was going for the smoked look that keeps some shine and mine came out flat (no shine whatsoever). Yours looks great to me though, it definitely retains some of the shine. I'm curious also how it holds up. I may have to give this another go.
  7. Jun 20, 2011 at 7:25 AM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    :popcorn: nice job!
  8. Jun 20, 2011 at 8:46 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
  9. Jun 20, 2011 at 9:01 AM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    La Mesa
    2014 SSM Trd Off Road 4x4 Auto
    Was trying to figure out a way to do this as well. Tried just buying them but that was a dead end
  10. Jun 20, 2011 at 10:15 AM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Looks good. Hit it with more clearcoat though - can't have too much shiny!
  11. Jun 20, 2011 at 10:22 AM
    thainess
    thainess Well-Known Member
    Sugar Land, tx
    10 prerunner trd offroad
    Plasti-dip emblems
    looks good
  12. Jun 20, 2011 at 12:00 PM
    azchris
    Phoenix
    I'll try to take a close up pic with my DSLR today so you can see the detail better. It's still a little speckled, but it looks more like Magnetic Gray than splotchy paint. It's a nice effect. I definitely want to add some more clear coat though to shine it up and protect it.
  13. Jun 20, 2011 at 12:21 PM
    GatorComa
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    If it's almost magnetic gray instead of black, do you think it would look good on a MGM truck or would it be too much of a match?
  14. Jun 20, 2011 at 1:00 PM
    azchris
    Phoenix
    I think it's a little bit darker, but I'd have to compare side-by-side. Here's a pic of it after I added another layer of clear today:
  15. Jun 20, 2011 at 2:22 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    1999 Scooby Doo LGT 2008 P71
    Yes
    Looks good. I experimeted with mine a while back but I used VHT nightshades instead. It looked awesome but didn't bond very well. I'm sure I could have got it to work with a couple layers of clear over it though.
  16. Jun 20, 2011 at 4:53 PM
    mavrick0509
    mavrick0509 Well-Known Member
    Hallettsville, Tx
    09 TRD Sport 4x4
    3" Suspension Lift, 285-75-17 Nitto, Painted Sport Wheels, Retro Projectors, Elusive Elements Grille, Flowmaster Muffler Swap
    I did this today and it came out great! Did exactly how you did. Great write up
  17. Jun 20, 2011 at 6:55 PM
    GatorComa
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    I gotcha, well it looks real good! I like it a lot (finally something other than plasti-dip haha)
  18. Jun 20, 2011 at 10:17 PM
    azchris
    Phoenix
    I was at my friend's paint shop today and I held it up next to a Toyota swatch - this paint would NOT look good on MGM. It's about the same darkness, but it's very green compared to MGM. Different hues, same shade of gray.
    The emblems are going back on the truck tomorrow! I'll be sure to update the thread with the final pics. The Toyota Tacoma and V6 emblems turned out way smoother than the Prerunner one, because I laid the paint down better. It's all in the technique.
  19. Jun 21, 2011 at 2:13 PM
    azchris
    Phoenix
    Added the last two steps :D
    Step 9
    Results
    It's hard to tell in the pictures but it is very reflective, like chrome. Overall I'm pretty happy with it, but we'll see how well the paint holds up. I'm a little skeptical about painting over chrome.
  20. Jun 21, 2011 at 7:17 PM
    GatorComa
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    Looks great on your truck, I like it on the silver :thumbsup:
