Smoking Clutch, Clunking while shifting
Discussion in '4 Cylinder' started by sachou, Apr 5, 2010.
  1. Apr 5, 2010 at 10:51 AM
    sachou
    sachou [OP] Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I've owned my truck for about 6 months now, and have put on about 5k miles. The previous owner claimed to have replaced the clutch himself at around 125k miles and it now has 140k miles. It's a 1999 4 cylinder 4wd, stock 4.10 gearing with 32" tires.
    I first encountered this problem last winter screwing around in parking lots in 4wd nearly bumping my rpms off the limiter, the clutch started to smell real bad. It went away after a little while and I disregarded it until I went to the dunes last week and, getting out of a deep, sandy section with the wheels spinning like crazy (I'm supposing, since I was WOT at 5k rpms 4hi, 1st gear, and moving really slowly). When I got over the crest there was a smoke coming from under my hood and the godawful burning clutch smell.
    The next day I drove 400 miles to Seattle, notorious for horrible traffic and steep inclines. After being in traffic for half an hour, I pulled into a parking garage to the wonderful burnt clutch smell.
    Ever since I bought the truck, it has clunked while shifting IF you give the throttle gas to get the rpms to match the road speed. But IF you just engage the clutch without giving any gas, it syncs up smoothly.
    I did a few clutch tests and I don't think it's slipping, but it does seem the friction zone is much smaller than before.
    What's going on here?
  2. Apr 5, 2010 at 10:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    I think you have burned the clutch plate up and put hot spots on the flywheel.
  3. Apr 5, 2010 at 11:00 AM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    Dunno if thats right or not, but you may want to check into it.
  4. Apr 5, 2010 at 11:25 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    I would recommend changing the clutch, and maybe replacing the fly wheel. sound like a burnt clutch. Iv only had mine on for about a year now, and im not going to use this clutch again.
