Smoking diff from low fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CFFC, Jan 29, 2024.
  1. Jan 29, 2024 at 2:17 PM
    CFFC
    CFFC [OP] Member
    Carlos
    2006 Silver Tacoma Double Cab PreRunner 2WD
    Stock
    The diff on my dad’s auto ‘06 PreRunner 2WD leaked the diff fluid to the point it started making noise and smoking. He found this one on https://www.ebay.com/itm/375181288152 but it doesn’t have the e-locker his has, what’s the difference in that? Is that something that could be added later or will he just be without it from now on? It’s strictly a work truck, he doesn’t do any offroading. Can we swap the guts from this new rear end and make it work with his? We’re both even thinking of just refilling it with new fluid and seeing how it behaves in the meantime. Thanks in advance guys.
  2. Jan 29, 2024 at 2:19 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    If it’s the entire rear axle, yes, you can use it. If it’s just the diff, non elocker and elocker diffs have different housings and are not interchangeable.
  3. Jan 29, 2024 at 2:23 PM
    CFFC
    CFFC [OP] Member
    Carlos
    Stock
    How can I figure out what gearing he needs? Is the 3.73 the correct ratio for auto 2wd? Or is 3.58 the ratio?
  4. Jan 29, 2024 at 2:47 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    vin plate on the door jam will have the diff code
  5. Jan 29, 2024 at 3:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if its a v6 6 lug truck its 3.73 regardless of any options.
    TnShooter likes this.
  6. Jan 29, 2024 at 3:49 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Some 05-08 trucks had a LSD differential, others did not.
    Either one will work. If your father’s was LSD and the other isn’t. You’d be down grading.
    Again, it will work either way.
  7. Jan 29, 2024 at 4:00 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    I thought stick shift had 4.10s. I have no clue but thought I read that somewhere here, which may be why op was asking about gearing
    I would top it off and run it. At least to hear it and know for sure it’s toast before shelling out the cash
  8. Jan 29, 2024 at 4:42 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Smoking differential. Damn that was hot. Ruined seals and cooked bearings at a minimum.
    OP was it howling?
    Never mind I went back and reread your post:
    "The diff on my dad’s auto ‘06 PreRunner 2WD leaked the diff fluid to the point it started making noise and smoking."
    Making noise and smoking. Its done.
  9. Jan 29, 2024 at 6:24 PM
    nd4spdbh
    SoCal
    Nope. Only 6 lug trucks that came with 4.10s were the inline 4 engined models.
    If the diff was smoking and making noise... It's 100% done, every bearing, gear set and seal is done in that thing.
    AllTacosFloat[QUOTED] likes this.
  10. Jan 29, 2024 at 9:51 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Little question while we are on the topic of diffs,
    I can swap my v6 4x4 auto diffs for 4 cylinder 4x4 diffs, correct?
    and am I right the locker didn’t come on the 4 cylinder taco
  11. Jan 30, 2024 at 4:15 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    you can also go the ECGS route to get a diff. Send yours in as a core. V6 has 3.73 and I4 has 4.10
