Smoking gun...or engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by Streettaco, Aug 19, 2016.
  1. Aug 19, 2016 at 9:51 PM
    Streettaco
    Streettaco [OP] Member
    Erik
    96 4 cyl
    N/A
    I thought it a smart idea to drive my Tacoma through a fair sized puddle on the side of a dirt road. When I pulled my 96 2.7 L out it started to smoke and it seemed either the engine wasn't getting enough gas or something was wrong with the clutch it had a hard time starting any one got any ideas?
  2. Aug 19, 2016 at 9:58 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    How deep was said puddle? Usually if you drive through puddles, it'll cool your exhaust rapidly and it'll smoke for a few seconds. No big deal.
    However the latter problem is more concerning. Can you describe it a little better? Did it throw any codes?
  3. Aug 19, 2016 at 10:03 PM
    Streettaco
    Erik
    96 4 cyl
    N/A
    Limping it home just now it flashed me a blinking check engine light isn't that for misfiring in the cylinder?
  4. Aug 19, 2016 at 10:04 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Not too sure on what a blinking CEL means. Regardless, try to pull the code.
  5. Aug 19, 2016 at 10:06 PM
    Streettaco
    Erik
    96 4 cyl
    N/A
    Pull the code? How do you do that and what is it?
  6. Aug 19, 2016 at 10:07 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    ... Get a code reader, hook it up, and put up what it says. That'll help us pinpoint the problem.
  7. Aug 19, 2016 at 10:09 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    I think it usually meant there a major issue with the engine but not sure
  8. Aug 19, 2016 at 10:19 PM
    GreekPEguy
    GreekPEguy Well-Known Member
    California
    2002 Prerunner, 3.4 TRD OR
    Usually a blinking CEL means it's something major and should not be driven.
    Brie likes this.
  9. Aug 19, 2016 at 10:20 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Just googled it real quick.
    A few different answers, but most of the time people are saying that it is flashing due to the engine misfiring. Same people also suggested to not drive fast, slow and steady is the goal until fixed.
    I still find this kinda strange because when my old '98 misfired, it had a steady check engine light and never "flashed". Replaced the spark plugs and it was good to go, drove completely fine after that.
    This is a total guess but maybe you damaged the cat converter while you were in the puddle? Other potential problems could be Plugs&Wires, MAF, Injectors, EGR, fuel filter, etc.
    Brie likes this.
  10. Aug 19, 2016 at 10:26 PM
    Streettaco
    Erik
    96 4 cyl
    N/A
    Sounds expensive this should be fun
  11. Aug 20, 2016 at 7:51 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Hopefully its something simple, like a wet distributor or water in the spark plug 'wells'.
    Thats what I would check out first.
    I just can't see how going thru a 'puddle' would cause a motor-destroying amount of water getting into the intake, which is about 3 feet above the ground near the passenger outside mirror.
    Brie likes this.
  12. Aug 20, 2016 at 8:49 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Something got wet and is causing the missfire, give it time to dry out and hopefully it'll clear up.
  13. Aug 20, 2016 at 5:38 PM
    Brie
    Brie Well-Known Member
    Brieanna
    CA
    2001 Tacoma TRD, Prerunner & 2016 Taco Sport
    Take it to auto zone, they will read your code for free... just ask them and they will show you how its done
  14. Aug 20, 2016 at 5:41 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Water on your spark plugs or in the spark plug holes.
    I had the same thing with my '95.5 5 lug (2.4L 5 speed) after doing donuts in a muddy/wet area.
    Pull the plug wires and blow them and the spark plug holes out with compressed air.
    Brie likes this.
  15. Aug 20, 2016 at 5:47 PM
    Brie
    Brieanna
    CA
    Is it driving any better today? Maybe all this is unnecessary as it is now dried up and running fine. An update would be nice..... we CARE
  16. Aug 21, 2016 at 4:33 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    The repair manual (1996) says the blinking CEL is for P0301-P0306 (misfire cylinders 1 through 6):
    • For any particular 200 revolutions of the engine, misfiring is detected which can cause catalyst overheating (This causes MIL to blink)
    • For any particular 1,000 revolutions of the engine, misfiring is detected which causes a deterioration in emissions (2 trip detection logic)
    So the misfire codes could cause the CEL to blink or not. In the blinking case it's more severe and driving will allow a lot of unburned fuel to leave the engine and cause the catalytic converter to overheat which could kill it. If the CEL lights for a misfire, but is not blinking it's less severe, and it should be safe to drive short term without causing more damage.
    Brie likes this.
