Smoooth
Discussion in '2nd Gen. Tacomas (2005-2015)' started by windmill65, Jul 18, 2017.
  1. Jul 18, 2017 at 8:01 PM
    windmill65
    windmill65 [OP] New Member
    Hey Guys my 79 year old Dad drives a 2012 Extra Cab TRD 4wd and wants a smoother ride. He drives unpaved roads everyday and substandard blacktops. He said he could " fix it" by buying a Tundra , LOL, but he likes his Tacoma. Thoughts / Ideas / recipes ?
    Thanks for all the GREAT pics and Threads !
  2. Jul 18, 2017 at 8:25 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Kings long travel set up...JUST DO IT
    ChadsPride likes this.
  3. Jul 18, 2017 at 8:27 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW!
    Kings set up Or full icon stage 2 or stage 3 set up
  4. Jul 18, 2017 at 9:59 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I honestly don't know if it's possible to make the tacoma feel like riding on a cloud smooth unless maybe you did go with a long travel setup and got it all dialed in. By nature, aftermarket suspension tends to have even higher spring rates than stock which while may come in handy off road seem to have the opposite effect on road. Sudden bumps such as potholes or cracks in the pavement would likely become more obvious with coilovers and such. This is just my guess however as I have only had the pleasure to ride in a few different setups with icon, fox and king so my opinion is limited.
  5. Jul 19, 2017 at 5:00 AM
    windmill65
    Thanks for the input Guys ! I know KINGS will get it done, looking for all options first.
    tcjacado and ChadsPride like this.
  6. Jul 19, 2017 at 8:01 AM
    WillyJam
    WillyJam Well-Known Member
    Send us pics for the before and after once project is completed.
  7. Jul 19, 2017 at 8:16 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    lincoln or cadillac should make a pickup... ;)
  8. Jul 19, 2017 at 8:17 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  9. Jul 19, 2017 at 8:22 AM
    Pigpen
    Dan
    Northwest Montana
    Larger diameter tires roll over obstacles more smoothly. A little less air in those tires makes for a buttery smooth ride. On long drives over rough roads I air my 255/85/16 tires down to 30 psi (normally drive them at 40 - 45). It makes a HUGE difference.
    windmill65[OP] likes this.
  10. Jul 19, 2017 at 8:23 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The Tacoma does ride smooth. If he wants smoother he needs to consider not having a truck at all.
  11. Jul 19, 2017 at 8:33 AM
    bluezzy
    Monty
    Eugene, Oregon
    If he gets the ride all super smooth it will sag pretty bad if tries to haul anything.
  12. Jul 19, 2017 at 8:36 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    OME with softer-rate springs is a less expensive option and won't be buttah-smoov, but will make washboards and substandard blacktop more pliant.
    And +1 on fiddling with tire pressures.
    ChadsPride and windmill65[OP] like this.
  13. Jul 19, 2017 at 8:46 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    bluezzy[QUOTED] likes this.
  14. Jul 19, 2017 at 8:48 AM
    bluezzy
    Monty
    Eugene, Oregon
  15. Jul 19, 2017 at 3:22 PM
    WillyJam
    Excellent advice. Well put ;)
  16. Jul 19, 2017 at 7:47 PM
    windmill65
    Thanks Guys, The air pressure is a good option to look into.
    My built '85 on 37's rides smooooth w 12psi but that's not good on the highway. I also have a 2010 Raceway blue, 4 door TRD Taco , a 2009 F350 srw CC diesel 4x4, a 2005 F150 STX 4x4, and a 2001 F250 on 39's. I love Toyota's as does my Dad , BUT , TRD Tacoma's are not smooth riding off - road. The 01 F250 is like driving a sofa, the F 350 rides very good, the '85 rides pretty darn good for what it is, the F150 is stiff, and the 2010 Tacoma is agile, nimble,fun and rough riding at slow speeds off road.
    My 79 year old Father says his TRD truck smooths out at about 35mph on washed board and bumpy dirt roads. He enjoys driving slowly through the farm and woods early in the mornings and his truck rides ROUGH and he feels all the bumps at 15 mph. His '89 rode much better.
    I am looking into a OME kit for him.
    Thanks
  17. Jul 19, 2017 at 8:04 PM
    windmill65
    My Dad has driven more miles off-road than Ivan Stewart ! He has owned many new trucks of all varieties , yet loves Toyota's the most. He wishes Toyota still made small trucks, instead of mid size Tacoma's.
    His truck gets washed and serviced regularly, yet stays dirty, because he drives Off - Road EVERYDAY ! He knows his TRD Sport was made to hammer on, but he bought it , just like most do, because it was cool and sporty. It rides rough. Perhaps you should quit taking pics of your truck and venture out more ....He already has an Avalon.
  18. Jul 19, 2017 at 9:27 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    The sport has a stiffer suspension. A progressive setup would work well for him (Fox, King, ADS) but the digressive Icon may be too stiff for his liking.
    PM Marie @HeadStrong Off-Road. She'll get you a proper setup at a good price.
    I'm running Fox 2.5 extended travel coilovers with the swaybar removed and a Dakar leaf pack with the 3rd leaf removed and Fox 2.0 remote reservoir shocks and happy with the off-road ride.
  19. Jul 20, 2017 at 5:55 AM
    PackCon
    Connor
    If I wanted to off-road, I would have bought a Jeep, not a TRUCK. I have zero interest in off-roading. Zero. I'd rather stab pencils in my thigh and see how many fit before I bleed to death.
  20. Jul 20, 2017 at 6:50 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Like stickyTaco said,the Sports have higher spring rates than the OR. I would look into a coilover setup,but it'll cost ya.
