Smoother ride on lifted 15 taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oranges232, Jul 2, 2021.
  1. Jul 2, 2021 at 7:00 PM
    Oranges232
    Oranges232 [OP] Member
    Jordan
    2015 silver TRD pre runner
    3.5 lift kid
    What can I do for a little smoother ride 2015 tacoma with 3.5 rough country lift ? Yes I get stock is better but I love the look . Is the coil over shocks worth it ? Fox 2.0 ?
  2. Jul 2, 2021 at 7:06 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    You have pics of what you have on the truck now. And it's called Rough Country for a reason.
  3. Jul 3, 2021 at 12:04 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Let some air out of the tires
  4. Jul 3, 2021 at 12:10 AM
    JoshS
    JoshS Well-Known Member
    Josh
    2014 Tacoma TRD Sport DCSB 4x4
    What tires do you have?
  5. Jul 3, 2021 at 12:18 AM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
  6. Jul 3, 2021 at 5:57 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    The ride is not rough because of the lift. It is rough from the choice of lift. There are other higher quality/smoother riding lifts that you could've chosen than RC. Your only choice besides lift replacement would be lowering psi or swapping tires to a less aggressive lower load rating tire.
    gotoman1969 and Oranges232[OP] like this.
  7. Jul 3, 2021 at 7:06 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    It's not the lift, it's the front/rear shock absorbers/leaf springs that cause a harsh ride. I'm running the RC 6" lift with Vertex front/rear shocks and All-Pro standard leaf springs. The truck rides smoother than my wife's camry.
    Operator8 likes this.
  8. Jul 3, 2021 at 7:16 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Can't compare your 6" RC drop bracket lift with the 3.5" RC lift. Apples to oranges, both have their own limitations.
  9. Jul 3, 2021 at 7:34 AM
    MA_TACO
    Wesley Chapel, FL
    I beat the snot out of mine and have had no issues, however, drop bracket lift or not the ride quality comes down to shocks and leaf springs.
  10. Jul 3, 2021 at 8:04 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Yes and no. With the db kit you still have basically the same amount of suspension travel as stock due to everything basically being lowered 6” so the geometry stays the same. With the spacer kit he has lost down travel as his suspension cycles which will cause a rougher ride even if he throws a nice set of coil overs in may help but won’t help with the loss of down travel if he keeps the spacer. But then again rough/smooth ride is all subjective to who is sitting in the seat.
    Wattapunk likes this.
