Smoother Ride
Discussion in 'Suspension' started by tacomaclay, Aug 28, 2007.
  1. Aug 28, 2007 at 12:13 PM
    tacomaclay
    tacomaclay [OP] Well-Known Member
    SR5 4x4 04
    Flowmaster exhaust, K&N 77 series intake, kobalt aluminum toolbox
    Is there a suspension system I can get that will not lift or lower my vechile but make it run smoother. If anyone knows please give me website adress.
  2. Aug 28, 2007 at 12:47 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    whats wrong with your ride now? too stiff, too loose, too bumpy? alot of times the rear tires are overinflated and cause a bumpy ride. you may wanna check the tire pressure all the way round.
  3. Aug 28, 2007 at 7:17 PM
    tacomaclay
    SR5 4x4 04
    It is to bumpy at high speeds and I have check the tire psi and they are what toyota recomends. Thanks anyway though
  4. Sep 1, 2007 at 10:15 AM
    tucsontoast
    tucsontoast Active Member
    Everybody seems to overlook the point at which the truck contacts the road. Tires. I really love the firm ride my 07 Prerunner has, and the way I can zoom right off those tall pavement to dirt transitions on roadsides kix ax. I really like the BFG's it came with, but you may consider a tire more aimed at smooth riding comfort instead of an all terrain like the ones your truck probably came with. Ask your tire dealer for suggestions. They should be able to tell you which provide a smoother softer ride. If they can't, go to another dealer.
    Good luck!
  5. Sep 2, 2007 at 10:44 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    take a look at the nitto homepage for the nitto dura grapplers. they're a primarily on road tire. they have the best ride quality of all their tires. if u dont plan on going off road any or much, then i'd look at them
