Smoothest 2.5"-3" Ride:OME or Fox/King/Icon?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Jul 8, 2011.
  1. Jul 8, 2011 at 9:37 AM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    Yes, I've searched and REsearched for hours. From my understanding, the OMEs are designed for up to 2" lift but sometimes give 2.5" of lift and spacers are required for the full 3" of lift. The high-end COs are for up to 3" with optimal lift about 2.5" with no preload. Is this all correct?
    With a 2.5"-3" lift, I really want a nice on road ride, with the off-road ride less important but a bonus since I'll only offroad maybe 1-2/yr at most.
    Of course the high-end COs are a lot more expensive, but I'll pay it if the ride is that much better on road.
  2. Jul 8, 2011 at 9:47 AM
    bskin
    bskin Well-Known Member
    Eagle River AK
    2016 DC TRD Off Road MT
    The Kings are really smooth on the road, but it depends on valving, springs etc. I think without any preload they are closer to 2 inches of lift rather than 2.5.
  3. Jul 8, 2011 at 9:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    To add: the OME 885 springs give 2.5 to 3" lift without the use of spacers.
  4. Jul 8, 2011 at 9:48 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    maybe just get a set of billy's and call it a day?
    good luck..
    BTW, I like my Icons but they are pretty stiff onroad.
  5. Jul 8, 2011 at 9:49 AM
    tacomtn
    Thanks for your responses.
    The factor for cost: UCAs.
    W/O extended travel, the LR UCAs are fine being ball joint vs. uniball? Correct?
    Is the 885 coil giving more lift due to a higher spring rate, not length?
    I think now, based on costs and my needs/wants, its between:
    1) Kings front, Billies rear (not a good match?)
    2) Kings front, Fox or Icon rear
    3) OME all around (But no adjustable preload collar?)
    AND LR UCA (cheaper, less maintenance, no squeaking)
    My goal is an even 2.5"-3" smooth riding lifted truck
  6. Jul 8, 2011 at 9:51 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i say go king. icons are stiff unless your haulin ass.
  7. Jul 8, 2011 at 10:00 AM
    tacomtn
    Another vote for Kings. Hmm, I'm leaning more that way too.
    97yota. Thats a great pic of your truck catching air!!! I dont have desert roads near me otherwise I'd love to hit trails like that.
  8. Jul 8, 2011 at 10:02 AM
    bskin
    Eagle River AK
    This, if you are only looking for 2.5 of lift and want a smooth ride then this is the best option, if you have the $$. I'm running these with the 600lb springs about 2.5 of lift and no sway bar and they are really smooth.
  9. Jul 8, 2011 at 10:06 AM
    WhiteWiddow
    WhiteWiddow a member
    Lucas
    Washington State
    06 SR5 V6 TRD Sport DC LB 4X4
    Same ish everyones doin
  10. Jul 8, 2011 at 10:11 AM
    tacomtn
    Yeah, the Fox's are pretty sweet too. I saw that DSM offer too, with their own UCAs. Not bad. Or how about Kings non-ext travel for $1045+$375 for a LR UCA=$1420 ? Not bad either?
  11. Jul 8, 2011 at 10:12 AM
    tacomtn
    What UCA and rear lift did you go with? Is yours a DC?
  12. Jul 8, 2011 at 10:20 AM
    bskin
    Eagle River AK
    I have TC UCAS and the Icon 3 leaf AAL in the back, my truck is a AC
  13. Jul 8, 2011 at 10:21 AM
    tacomtn
    What rear shocks?
  14. Jul 8, 2011 at 10:23 AM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    why not just go for billies if you aren't offroading???
    You don't need King or Fox for 2 off raod trips a year.. that's over kill / mall crawler stuff
  15. Jul 8, 2011 at 10:24 AM
    bskin
    Eagle River AK
    Just went with 5100's in the back for now
  16. Jul 8, 2011 at 11:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you order them from DSM, You can have them take out some of the low speed compression dampening (they do this one time for free), and it makes them much softer on the street.
  17. Jul 8, 2011 at 1:04 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    Honestly, I vote for KINGs.
    My truck rides better lifted than it did when it was stock. Then again, its all in my head. My truck rides very smooth on the road and handles well off the road. The only thing that gets in my way, is the front bumper. That will be solved soon.
    However, I'm a Prerunner and had the option to add a Spindle lift and have NO preload on my Kings. So thats not an option for you. =(
    I did have my Kings cranked up before and it road very well. However, not close to how it is now. . . .
    I'd get KINGS if you can swing it. They will last you. . . Then 5100's in the rear. If you can, get Kings back there too. . . ​
    Cheap Route
    5100's all around. I had it and it did well but stiff.
    Light Racing UCA
    TSB OEM Toyota 4-Leaf Leaf Springs.
    Middle Route
    Kings up front
    5100's in the rear
    Camburg or TC UCA
    Toyota 4 Leaf TSB Rear Leaf Springs
    Improved Route
    Kings 2.5 all around
    Camburg or TC UCA
    All Pro 3" Rear Leaf Spring
    You can always have cash on hand and keep an eye out of Used Parts. Thats what I did. I suggest this route also. You can get the best without breaking your wallet. Good things comes to those who wait.
  18. Jul 8, 2011 at 3:48 PM
    So.Cal Taco
    So.Cal Taco Well-Known Member
    Jeremy
    So.Cal
    1996 4x4 v6
    Total Chaos Long travel Total Chaos Spindle Gussets, Nathan Air Chime K3LA's,Onboard Air system,K&N intake,Chuys 200 plus Amp Alternator,All Pro front Bumper,Lots of Dynamat,99 tacoma Gas Tank Mod ''Secret'' maybe I'll Tell
    I have the King 2.5's with 650 pound springs with Tundra valveing on my Taco because of the heavy front ARB bumper with Winch The ride is Great.
  19. Jul 8, 2011 at 5:35 PM
    tacomtn
    Yeah, Kings/Fox's may be overkill for my use (99.99% road, 0.01 offroad). Funny thing. The high-end COs are rebuildable but they also MUST be rebuilt every 30-50k miles. Whereas the OMEs or Bilsteins will last longer then just dispose of them and get new ones every 70k or more, and still cost less than one pair of Kings/Foxs.
    Choices, choices. That deal of $1045 for the Kings RR is a sweet deal though. But can I use LR UCAs or must I use the more expensive uniball UCAs? The Kings are not ext. travel.
  20. Jul 8, 2011 at 8:11 PM
    2_wheels
    2_wheels Well-Known Member
    Coeur d'Alene, ID
    06 Tacoma TRD Sport 4x4 dbl cab
    I have kings front and rear with TC UCA's and OME Dakar rear springs with one over load removed.
    AWESOME ride on the road, way better than stock. Very cushy offroad too. If I were doing more high speed stuff off road I'd slow down the rebound a bit up front and give it a little more preload.
    lifted it about 2.5 up front and over 3 in the rear, still has a slight rake to it until I put my camping gear and dirtbike in the back.
    Oh- mine is a DCLB.
