Snailed my Tailgate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FL_TRD Sport, Jul 27, 2021.
  1. Jul 27, 2021 at 2:52 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Link to ‘that other one’?
  2. Jul 27, 2021 at 2:55 PM
    dagobert
    dagobert Well-Known Member
    I need to pull my head out of the gutter..
  3. Jul 27, 2021 at 2:57 PM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    By attached to the tailgate, is that just the glue holding it and then you put the armor over it? Did you get the 4" or XL size?
  4. Jul 27, 2021 at 3:24 PM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    Just the glue. I put the original screws in the panel to line it up against then decided that I liked the look. The glue has an accelerator that you put on first, that makes it damn sticky and it works fast. You only get one chance so make sure you have it all laid out correctly before the install.
    I believe that the gap shield brand is the one that attaches to just one side.
  5. Jul 27, 2021 at 3:30 PM
    cop414
    Tim
    Central PA
    This is the one that I used.
  6. Jul 27, 2021 at 3:50 PM
    FL_TRD Sport
    FL_TRD Sport [OP] Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I almost forgot. If you decide you can't live without one I used a coupon code ADVENTUREBUILT15 which took 15% off the price. Every little bit helps :)
    Aqualoon[QUOTED] likes this.
  7. Jul 28, 2021 at 7:06 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Did you happen to consider the Mountain Hatch? I"ve been thinking of doing something like this but can't decide between plastic and metal. Metal might get hotter but maybe looks better. The Mountain Hatch "might" be a bit nicer to sit or kneel on, but it's over-engineered (I don't need all the CNC work) and pricey. Not sure how well it fits over that ridge on the tailgate either. With the various coupons I found though it's about $30 more for the MH.
  8. Jul 28, 2021 at 7:13 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    I did consider them. It was between Mountain Hatch and the SnailArmor. I went with the SnailArmor because it was metal, somewhat cheaper, and I didn't need a cutting board or cup holders. I just wanted a flat surface to make it easier on my knees and to be able to rest items, and SnailArmor fit the bill.
  9. Jul 28, 2021 at 7:18 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    I currently have a piece of carpet Velcroed on the tailgate to make it more comfortable and I might leave it even with the flatter cover. The carpet makes a bit more flat (but stuff still tips over if I'm not careful) and easy on the knees and my camping stove doesn't slide around. Probably get the snail as well. Thanks for the feedback.
  10. Jul 28, 2021 at 2:56 PM
    soysauce021
    soysauce021 Well-Known Member
    Bay Area, CA
    2021 DCLB Sport
    I have the snailarmor (flush screws) as well as the rokblock. Loving this setup. I do a lot of things around the house so having metal vs plastic just get more durable for my uses.
    My snailarmor also came with a “prototype” cup holder too. Works really well actually and it doesn’t get in the way. Plus it’s removable.
  11. Jul 28, 2021 at 2:58 PM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    I got the flush mount screws but didn't get the prototype cup holder. If it's removable I would have tried it but I don't think I'd use it much if at all.
  12. Jul 28, 2021 at 3:30 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Is that the default now or do you have to select the flush mount and cup holder? I didn't see any options other than engraving.
  13. Jul 28, 2021 at 3:36 PM
    soysauce021
    Bay Area, CA
    2021 DCLB Sport
    It comes with the machine screws (I think that’s what they’re called) so you have the option of using the stock screws which are raised or the machine screws which are flush.
    the cup holder was just a throw in and I don’t know if they are selling it.
