Snapped bed bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Derk33, Sep 17, 2017.
  1. Sep 17, 2017 at 7:21 PM
    Derk33
    Derk33 [OP] Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    Bed bolt was loose and was going at it with the impact gun when the bolt snapped off right at the top of the threads. Any ideas on how to get the rest of it out?
  2. Sep 17, 2017 at 7:25 PM
    jasonl275
    jasonl275 Active Member
    '11 DCSB TRD OR 4X4 6MT
    Screw Extractor? I haven't used it on anything as large as a bed bolt, but It should work the same
  3. Sep 17, 2017 at 7:27 PM
    Derk33
    Derek
    Pennylvania
    I've never have very good luck with them but I'll try it tomorrow, just figured if the impact couldn't get it out a screw extractor wouldnt be much help
    TacoCat likes this.
  4. Sep 17, 2017 at 7:28 PM
    jasonl275
    drench it with some PB Blaster and let it do its thing for a few minutes then give the screw extractor a shot
  5. Sep 17, 2017 at 7:28 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    If the box will lift off past it (which it sounds like it will) you can just take a zip wheel to the u-nut where it folds over the frame rail (cut it in half) and the leftover bolt should just fall out.
    Or, weld a nut to what's left and finish twisting it out.
    TacoCat and Bulldogs129 like this.
  6. Sep 17, 2017 at 7:30 PM
    Derk33
    Derek
    Pennylvania
    it was drenched from the start but I'm going to let it sit over night
  7. Sep 17, 2017 at 7:32 PM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    What WHPLS3 said... right on target
  8. Sep 17, 2017 at 7:37 PM
    Derk33
    Derek
    Pennylvania
    there are still 5 bolts holding the bed down so there's still not much play in the bed and I don't have a welder :(
  9. Sep 17, 2017 at 7:39 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    One of my bed bolts was loose and it caused a ton of play when off-roading or going over bumps
    I would fix this for sure
  10. Sep 17, 2017 at 7:40 PM
    Derk33
    Derek
    Pennylvania
    Aren't the nuts for these bolts welded to the inside of the frame?
  11. Sep 17, 2017 at 7:40 PM
    WHPLSH3
    Vance
    Alberta
    Are you taking the bed off? Or we're you just trying to put in bed stiffeners or d-rings?
  12. Sep 17, 2017 at 7:40 PM
    Derk33
    Derek
    Pennylvania
    Just trying to stiffen up the bed, the bolt that snapped was the only one that was loose
  13. Sep 17, 2017 at 7:47 PM
    WHPLSH3
    Vance
    Alberta
    After a quick look at mine, I see that they are a welded nut... I was thinking they were like the Fords.
    Unfortunately, I think the only fix is to remove the bed so you can get at what's left...:(
  14. Sep 17, 2017 at 7:49 PM
    Derk33
    Derek
    Pennylvania
    Well shit..let's hope I don't break anymore of them
  15. Sep 17, 2017 at 7:51 PM
    WHPLSH3
    Vance
    Alberta
    I'm surprised the bolt twisted off like that... it usually the torx bit that gives up!
  16. Sep 17, 2017 at 7:56 PM
    Derk33
    Derek
    Pennylvania
    I'll take some pics tomorrow morning and it was just a husky bit from Home Depot, nothing special :notsure:
  17. Sep 17, 2017 at 7:56 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Take the rest of them out, remove the bed and attack it with a cut off wheel
  18. Sep 17, 2017 at 9:28 PM
    Muddinfun
    Muddinfun Well-Known Member
    There's several inches of threads sticking out past the nut. Try double nutting it on the bottom and working it back and forth with plenty of penetrating oil. Maybe you can get it worked up high enough that you can grab the top with vicegrips. If grabing the vicegrips at the bottom is your only choice, work the bolt up till the chewed part hits the nut and then cut the end of the bolt off.
  19. Sep 17, 2017 at 10:38 PM
    Derk33
    Derek
    Pennylvania
    This is the front(closest to cab) drivers side one and I believe the only way to access the lower half is through a small hole in the frame
  20. Sep 17, 2017 at 10:59 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    I'd take the bed off and dick around with it. Use heat instead of lube on the remaining bolts, it'll expand the metal around it and make it easier to remove. I've found that an oxy-map torch does the job well but map alone is fine too, getting them red hot would be optimal. If you wanna use lube try the acetone and atf mix. As for the broken bolt, heat it and try drilling it out with a left handed drill bit and extractor set. I haven't had much luck with extractors myself but left handed bits have worked. If the bit doesn't grab it and pull it out the first time then just drill into the bolt a good ways and use the next largest bit and keep going until it grabs it. Just my 2 cents on the situation.
