Snapped leaf spring?
Discussion in 'Suspension' started by RstyLeafSpring23, Jan 2, 2022.
  1. Jan 2, 2022 at 8:03 PM
    RstyLeafSpring23
    RstyLeafSpring23 [OP] New Member
    2008 TRD Sport Double Cab
    This is my first post here mostly out of necessity.
    My 2008 TRD Sport Double cab is nearing 224,000 miles and just today I was inspecting my leaf spring due to the wheel hop I was experiencing when accelerating normally from a stop, and a really rough ride over any sort of bump. I found that the bottom most leaf on the drivers side was completely snapped at the U-Bolts and resting on the axle.
    When looking into replacing the leaf spring it seems that all aftermarket springs 1: provide a significant lift 2: are more expensive than I would've imagined. Is there any reliable aftermarket options for stock height leaf springs? Is my best option to go with an aftermarket leaf pack such as the Dakars pack? Money is definitely a factor however I plan on doing all the work myself.
  2. Jan 2, 2022 at 8:23 PM
    the.shelbysaurus
    the.shelbysaurus Well-Known Member
    Colorado Springs, CO
    2019 Cavalry Blue SR5 4x4 ACLB
    Ironman 4x4 Foam Cell Pro, SPC UCAs, 285/70/17 KO2s, 1.25" Spidertrax spacers
    No idea where you're at, but if you're in WA I just took my stock leaf pack off the other week. I left it with my mechanic, but I'd guess he still has them if you want them. They were on for about 30k miles, mostly on-road, with some light forest service/fire road mileage.
  3. Jan 2, 2022 at 8:25 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    I'd grab a set of leaves from a 3rd gen that got lifted. In my area there are usually 2-3 sets on the various used places (Craigslist/marketplace)
  4. Jan 2, 2022 at 8:40 PM
    RstyLeafSpring23
    On the other side of the country but thanks for the offer!
  5. Jan 2, 2022 at 8:40 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    There was a recall on broken leaf springs. Ask your dealer about recall E02:
    https://static.nhtsa.gov/odi/rcl/2014/RCONL-14V604-5982.pdf
    https://static.nhtsa.gov/odi/rcl/2014/RCRIT-14V604-1484.pdf
    If your truck is eligible, you'd be able to get the leaf packs replaced for free.
  6. Jan 2, 2022 at 8:40 PM
    RstyLeafSpring23
    Is this just a straight up bolt on or is there any modification required?
  7. Jan 2, 2022 at 9:05 PM
    ZColorado
    13 DCSB OR 6MT
    Bolt on, although you will need new u-bolts. You dont want to re-use them.
    Where are you located? I have a set of used leaves off my '13 and some new u-bolts that might work too.
    Fun fact. toyota never changed the suspension components from '05-now. So all the basic components are the same (UCAs, shocks, coilovers, leaves)
