Snapped off CV axel (SOS)
Discussion in 'Technical Chat' started by 99Lifted, Aug 12, 2020.
  1. Aug 12, 2020 at 1:14 PM
    99Lifted
    99Lifted [OP] New Member
    99 Bedlined Tacoma
    Lifted, Geared down, Etc
    Doing a CV axel replacement on my Tacoma. After taking the outer axel out the inner fell out from the knuckle. Im now looking at a full of grease cylinder that needs to come out of the slot in the differential for the new one to slide into.. I see no edges to even begin to pry on and I'm currently at a loss. Anyone been in this situation?
  2. Aug 12, 2020 at 1:20 PM
    99Lifted
    99 Bedlined Tacoma
    I'll give it a try once I've stewed on it all day at work. Thank you.
  3. Aug 12, 2020 at 1:24 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Make a lasso out of like 1/8" steel cable or some heavier duty electrical wire. Wrap that tightly around the 'base' of the stub close to the diff. Make a closed loop on the other end.
    Now use a combination of a big pry bar as mentioned above, and someone else swinging a hammer (inside the closed loop) outward away from the truck. The combo of the steady force from the pry bar and the impact from the hammer / lasso deal should pop it out. Rotate whats left of the axle and try again if it doent work. Some people have really good luck and it practically falls out, others have to fight the whole way.
    99Lifted[OP] and whatstcp like this.
  4. Aug 12, 2020 at 1:32 PM
    99Lifted
    99 Bedlined Tacoma
    That actually doesnt look bad at all. Thanks again!
