Sneak Peek at the 2JZ (Lexus Inline 6 Motor) I am Cramming into my Ex-Girlfriend's Engine Bay
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tyler Lacasse, Feb 15, 2016.
  1. Nov 14, 2017 at 5:40 PM
    #281
    Tyler Lacasse
    Tyler Lacasse [OP] Well-Known Member
    Tyler
    San Gabriel
    2002 Regular Cab
    Gauge cluster is pretty :p
  2. Nov 15, 2017 at 12:04 PM
    #282
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    Cluster is out of what vehicle?
  3. Nov 15, 2017 at 12:37 PM
    #283
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    Wow!! What was the reason for pulling everything out? What a pain that must have been. I had a hard time pulling the stuff out of the Lexus, and that was whole ripping out and destroying a whole bunch of stuff in the process. Couldn't imagine getting all that out without breaking anything.
    Edit- that's the stock regular cab bench seat. It wasn't bad, but I am not a bench kind of person. Always loved the mild "hug" you get from bucket seats. Also, I'm able to scoot my seat forward a click and lean it back a bit. Lot more comfortable. On top of that, I can now put small groceries in the middle between the two buckets. What a huge difference the seat swap has made and it's only been a couple days so far with the setup!
  4. Nov 15, 2017 at 12:37 PM
    #284
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    2002 Lexus GS300
  5. Nov 15, 2017 at 12:44 PM
    #285
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I flipped my old truck and bought the new one on the cheap. The new one wasn't exactly what I wanted though (automatic and the engine was clapped out, still fully running and driving though). So I swapped the entire drivetrain and electrical system out of my wrecked truck and into this new one. Let me tell you there are a lot of changes from 1995-1996. Got really good at removing clips, plastic parts, entire engines, haha. She runs and drives great now.
    From this...
    To This... Car trailer was temporary, I was moving
  6. Nov 15, 2017 at 1:26 PM
    #286
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    How did you mount the Lexus cluster to the Tacoma dash trim?
  7. Nov 15, 2017 at 1:29 PM
    #287
    Speedytech7
    Used to have buddies with is300s, I thought they all had a much fancier cluster...
  8. Nov 29, 2017 at 5:12 PM
    #288
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    Little picture update.
    Seat is getting reupholstered by someone in my girl's family. I'm used to a Tacoma bench seat and now bucket seat. I cannot even say Lexus seat in the same sentence. Once you adjust it to your shape it is so much comfier than the taco seat. What a massive difference. If feels like a supportive lounge chair. It's absolutely awesome!!!
  9. Dec 2, 2017 at 11:04 PM
    #289
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    Truck officially ran and revved today. Only for a quick few seconds as the transmission spewed its blood everywhere and also no fluid in the power steering pump yet...
    Anyhow, pulled the old dash harness and put the Lexus one in. You can see where I crossed the wire paths on the driver side door jamb/floor rail.
    The plan is to splice the Lexus harness to the truck rear end harness. This means using the longer truck harness that's already running to the tail lights instead of lengthening the Lexus harness and putting connectors on it. It also means getting rid of the random wiring for the electronic trunk and gas door opener which makes for a cleaner install. Everything is going to work, but the only concern I have is the gas gauge... Will have to do some digging on that.
  10. Dec 3, 2017 at 6:12 AM
    #290
    tony2018
    tony2018 Well-Known Member
    You're using the is300 gas pedal?
  11. Dec 3, 2017 at 6:34 AM
    #291
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    It's the Toyota Tacoma gas pedal with the IS300 aluminum pedal tip that is held on via one or those expanding friction fit pins. I tried the whole pedal, but the Tacoma pedal fit like it should (better than the IS) and the aluminum pedal tip was easy to transfer over with some slight bending. The brake pedal assembly is from an 03 IS300, but this time it's coupled to a hydrobooster in the engine bay.
  12. Dec 3, 2017 at 6:36 AM
    #292
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    Always liked those! Reminds me of a nice watch
  13. Dec 3, 2017 at 6:37 AM
    #293
    CaptainAwesome
    CaptainAwesome Well-Known Member
    Calgary, Alberta
    I used to own a Lexus is300. Great motor. Lots of torque. I don't know why they stopped using the inline 6.
    Tyler Lacasse[OP] likes this.
  14. Dec 3, 2017 at 6:41 AM
    #294
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    Glad to hear the swap worked out good! Nice looking truck. I remember when I did the stereo system in my truck years ago and was like, "whoa, I'm getting pretty deep here...better now pull anymore stuff off" but now after taking this whole thing apart like you did, it feels like any kind of panel removal is easy now, which is awesome.
    Toyota loves to use those stupid zip tie looking clips, which are a pain to get off! Especially where we are digging into.
  15. Dec 3, 2017 at 12:21 PM
    #295
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    From last night to this morning
  16. Dec 3, 2017 at 2:41 PM
    #296
    Speedytech7
    Those zip tie clips are the worst, only way to get them out of a blind hole is to get under then with the thinnest panel remover and hope it hits the tabs.
  17. Dec 4, 2017 at 1:03 PM
    #297
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    Picked up an Apexi N1 today! Going to dump the muffler right behind the axle.
    Dalandser and randd like this.
  18. Dec 9, 2017 at 2:24 PM
    #298
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    This just in...!
    Dalandser and Brostjoe like this.
  19. Dec 10, 2017 at 10:47 AM
    #299
    Tyler Lacasse
    Tyler
    San Gabriel
    2002 Regular Cab
    Radiator mounting tabs, bung for Lexus factor fan temperature sensor, upper radiator tube, motor water output tube, power steering reservoir extra bung for hydroboost output, and reservoir bracket.
    RedLantern, tony2018 and Dalandser like this.
  20. Dec 10, 2017 at 10:51 AM
    #300
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Man that's a tight fit! Great job man! What is the impact of not having a fan shroud going to be? Do you think it will make a big difference? Do you have any room for one since the accessories are so close to the rad?
