Snorkel alternatives?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Dec 12, 2017.
  1. Jan 10, 2018 at 7:31 PM
    #201
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    ya, half of the last amber. The angle of the picture makes it look worse.
    It ok though..I think I have more than enough to make up for it.
    SuperBad[QUOTED] likes this.
  2. Jan 10, 2018 at 8:55 PM
    #202
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Somewhat related, what kind of lights did you use for your ditch lights?
  3. Jan 11, 2018 at 6:18 PM
    #203
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
  4. Jan 12, 2018 at 5:42 AM
    #204
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
  5. Jan 31, 2018 at 10:46 AM
    #205
    MESO
    State of Jefferson
    update-
    She's all hooked up and functional now. The Prado kit came with a "S" rubber coupler to route from the snokel to the intake box. It was close to fitting but was about 2" short. So I cut it in the middle, and put a 3" aluminum pipe extension in between. The hose diameter fits into the fender intake hole PERFECT. It was a tight fit where it hooks up to the snorkel inside the fender, but everything worked out.:bananadance: So all in I'm about ~$200. ($150 for the Prado 150 kit, which I used most of the components and ~$50 for the landcruiser where I just used the "L" intake scoop head out of it.)
    Grill is all coated and installed.
    here is a top view. It doesn't obstruct my view at all and sits as low/streamline as I could make it
  6. Jan 31, 2018 at 10:49 AM
    #206
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    So now that it’s all said and done, could the average joe whip one up or did you use your printer for anything? (I can’t remeber)
    ChadsPride likes this.
  7. Jan 31, 2018 at 10:53 AM
    #207
    MESO
    State of Jefferson
    I ended up not using anything 3d printed. I think the average person could do this now that I've been through the trial and error process. The hardest part is going to be where to cut a hole. Obviously there is no template... I just held it up, marked it, and went to town. Second, you could do the entire install with the Prado 150 kit for $150 but it comes with the "hairdryer" style intake scoop. Last, I did not drill holes in the a-pillar for the bracket mount because my roof rack was so close I make a bracket off that. So for anyone else, they would have to fab up a drop bracket to bolt higher up on the snorkel to the a-pillar. Hope this helps.
  8. Jan 31, 2018 at 11:57 AM
    #208
    erok81
    erok81 Well-Known Member
    Imposter
    What is the inside diameter of that top piece? I think I’m going to do one as well. But mine can just be a straight piece of aluminum from the top of the fender to that intake piece. The only bends will be inside the fender.
    TRDProDriver and mcharfauros like this.
  9. Jan 31, 2018 at 12:01 PM
    #209
    MESO
    State of Jefferson
    Diameter of what?
  10. Jan 31, 2018 at 12:15 PM
    #210
    erok81
    Imposter
    Inside diameter of the top piece. You have a tube that slides into the intake bit. I need to purchase that kit and some pipe. The pipe will need to slide into that intake piece.
    I guess I could just order the kit and measure myself.
  11. Jan 31, 2018 at 12:21 PM
    #211
    tcjacado
    tcjacado Well-Known Member
    Pipe diameter of 3 inch piece connecting the rubber s boot you cut in half.
    erok81[QUOTED] likes this.
  12. Jan 31, 2018 at 12:27 PM
    #212
    MESO
    State of Jefferson
    The top "intake head" is not circular. It looks more like a kidney shape. as well as the entire snorkel body. I assume it is this shape so it "hugs" the A-pillar closer.
    from there it goes into the fender with a oval hole (~7"X3") and into the S rubber boot. The other end of the boot drops down to a ~3.25" round outlet.
    hope this helps.
  13. Jan 31, 2018 at 12:37 PM
    #213
    erok81
    Imposter
    That does help. Maybe I’ll get semi thin wall aluminum and ovalize it a bit. Or in kidney shape the intake head.
    It’s never easy is it. :rofl:
  14. Jan 31, 2018 at 12:40 PM
    #214
    MESO
    State of Jefferson
    Especially when I had 0% to go off of. It was a eBay Guessing game by looking at pictures and cutting holes:laugh:
  15. Jan 31, 2018 at 1:01 PM
    #215
    erok81
    Imposter
    Well you did a damn fine job!
    MESO[QUOTED][OP] likes this.
  16. Jan 31, 2018 at 1:06 PM
    #216
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    Wow, that turned out pretty damn good man. Well done :thumbsup:
  17. Jan 31, 2018 at 1:09 PM
    #217
    MESO
    State of Jefferson
    Thanks! I don't half-ass 2 things... I whole-ass 1 thing:D
    RocTaco and Pistol Pete[QUOTED] like this.
  18. Jan 31, 2018 at 1:26 PM
    #218
    17taco4x4
    17taco4x4 FZJ80
    Orlando
    Porter, TX
    1997 Land Cruiser
  19. Jan 31, 2018 at 1:42 PM
    #219
    tcjacado
    If you put one on the other side of would look like a strong man flexing his biceps.:D
    J/k.
  20. Jan 31, 2018 at 1:44 PM
    #220
    MESO
    State of Jefferson
    you like big butts and you cannot lie
    mcharfauros and mikestaco17 like this.
