Snorkel alternatives?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Dec 12, 2017.
  1. Dec 18, 2017 at 6:03 AM
    #121
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    Looking forward to more on this
    ChadsPride likes this.
  2. Dec 18, 2017 at 7:04 AM
    #122
    erok81
    erok81 Well-Known Member
    Imposter
    Yeah that will be difficult to rotate. I really like the way the intake is set up on that one.
    I’m thinking I might just do the fender mounted intake and not bother with the full height snorkel. My fiberglass fenders have plenty of room to set an intake on.
  3. Dec 22, 2017 at 11:41 AM
    #123
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Update.
    Received snorkel. Too tall(kinda knew that anyway). Might work for someone without a roof rack. But I am going to chop the top down about 8" and design/3D print a new scoop for it.
    Couture to the cab it's pretty damn good! The issue will be where it mount to the fender...it's really hard to test fit with hose inlet lip around it (preventing it sitting flush)
    We shall see.
    Either way..I'm going to make it fit. Just because I hate the ARB version.
    PICS;
    Don't mind my super high speed low drag tape. I'll switch to heavy duty duct tape for the final version.
  4. Dec 23, 2017 at 4:37 PM
    #124
    Putzcommander
    Putzcommander Well-Known Member
    2016 Trd Sport Doublecab 5ft Box
    Softopper
    Can you slam some soft black closed cell foam between the snorkel and fender to get a better fit or is it too far?
  5. Dec 23, 2017 at 4:51 PM
    #125
    MESO
    State of Jefferson
    Thats what I was thinking about doing. Or design and 3d print a coupler to hug the fender perfect and match up to the snorkel.
    But after looking at this setup.. I might be changing it up.
    I have 3 ideas in the air right now:
    1) custom 3" stainless pipe curved to the windshield with snorkel head on top. Straight into the fender
    2)make custom ducting and turn the fake skewp into the air intake
    3) do a short ram style snorkel poking out the fender(not going up to the roof)
    Still thinking it over before I start cutting big holes...
  6. Dec 23, 2017 at 4:53 PM
    #126
    Putzcommander
    Softopper
    Id go for option 2. Not a fan of cutting bodywork unless required. Asking for rust. Plus i wanna see real skewp!
    Boghog1 likes this.
  7. Dec 23, 2017 at 4:54 PM
    #127
    Putzcommander
    Softopper
    No cool looking snorkel street cred though :anonymous:
  8. Dec 23, 2017 at 4:56 PM
    #128
    MESO
    State of Jefferson
    I'm on the fence between 1 and 2
    mcharfauros likes this.
  9. Dec 23, 2017 at 4:56 PM
    #129
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’ve read on here that the skewp is in a weird vacuum and actually a shitty place for an intake, as people have had that idea before. No idea if true, but I’d avoid that option.
  10. Dec 23, 2017 at 5:02 PM
    #130
    MESO
    State of Jefferson
    And that's why we collectively brainstorm:D
  11. Dec 23, 2017 at 5:16 PM
    #131
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    The snorkel is designed like a cyclone. It helps knock the dust out of the air before it makes it to the air filter. You can read about how they work with a quick Google search. Plus, the intake into your air box is in the wheel well so it pretty much just pulling dusty air in. Snorkels work, if they didn't they wouldn't be so popular.
    Edit: sorry if this info was already mentioned. I'm still working my way through the whole thread.
    Atlas86, JJ TACO, erok81 and 2 others like this.
  12. Dec 23, 2017 at 5:39 PM
    #132
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    It’s not a good place for ram-air but snorkel isn’t for that, only clean air. The cons for the skewp would be debris from following on a trail, snow (if that is a thing where you live) or low water run up on the hood. You would need a dump under the hood which could be routed over the passenger side before entering the stock air box.
    The slim fin design snorke intakes are not even aimed into the air flow. You don’t need any ram air unless boosting or cooling.
  13. Dec 23, 2017 at 5:58 PM
    #133
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Also, if you ever plan on going with 35" tires and have any plans of taking it off payment, you NEED a snorkel. 35's means no fender liners which exposes the open intake tubing in the passenger fender.
  14. Dec 23, 2017 at 6:01 PM
    #134
    MESO
    State of Jefferson
    Yup. I'm learning the hard way
  15. Dec 23, 2017 at 7:15 PM
    #135
    soup222002
    soup222002 Well-Known Member
    Amelia Virginia
    2017 DCSB TRDORD
    Meso your shop looks huge.
  16. Dec 24, 2017 at 9:32 AM
    #136
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    But everyone seems to forget those are glass sides so it doesn't look close to how it should
  17. Dec 24, 2017 at 9:55 AM
    #137
    MESO
    State of Jefferson
    I get that. But I still think a 3" pipe can go straight into the stock fender with minimal modifications. Only thing I would like is a nice trim/coupler bezel so it doesn't shoved into the hole
  18. Dec 24, 2017 at 9:59 AM
    #138
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    @mesojdm, what's the largest dimension you can 3D print? Seems like you could 3D print you own fender box, and then just reuse the A-pillar tubing to connect to your custom fender box.
    How much space is behind the stock fender? Can you print a narrow tube that would fit between the fender to get closer to the A-pillar before it "daylights"?
  19. Dec 24, 2017 at 10:05 AM
    #139
    MESO
    State of Jefferson
    That is my entire goal; bring the intake inside the fender as far back as possible so there is minimal tubing poking out up the the a-pillar.
    My printer can do ~2ftx2ftx2ft.
    I'm still debating if I even want to Frankenstein the existing snorkel I purchased or go 100% custom...
  20. Dec 24, 2017 at 10:10 AM
    #140
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    How about inside the engine bay? Can you get far enough back inside the engine bay, and then penetrate through the bay and fender in one shot?
    I'd go full custom for a perfect and cohesive fit. And also because "ME-SO"...
    MESO[QUOTED][OP] likes this.
