Snorkel effect on aerodynamics
Discussion in 'General Tacoma Talk' started by bbougenot, Apr 16, 2023.
  1. Apr 16, 2023 at 8:14 AM
    bbougenot
    bbougenot [OP] Member
    Basile
    2021 Green Tacoma TRD OR
    Hello TW members,
    Does anyone know if installing a snorkel has a significant impact on the aerodynamics of the truck? I’ve been wondering if the asymmetry of having just one massive safari snorkel would result in trucks being less streamlined and potentially pulling to one side especially at high speeds. Any thoughts?
  2. Apr 16, 2023 at 8:15 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I've noticed no ill effects from my snorkel install, not even an increase in wind noise.
    Stevie17 likes this.
  3. Apr 16, 2023 at 8:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Impact on aerodynamics, Yes. It will slightly increase your frontal area. Enough to affect driving, absolutely not.
    tcBob and Stevie17 like this.
  4. Apr 16, 2023 at 8:25 AM
    bbougenot
    Basile
    Ok good to know. My truck has been pulling slightly to the right and I was paranoid the Snorkel might be the reason why.
  5. Apr 16, 2023 at 8:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A snorkel won't cause that. Either the crown of the roads, or a small alignment issue.
    Blisterinthesun and Stevie17 like this.
  6. Apr 16, 2023 at 8:29 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
  7. Apr 16, 2023 at 8:31 AM
    bbougenot
    Basile
    Yeah unfortunately I just got the truck aligned yesterday and still have the same behavior (maybe slightly better). I think the alignment shop just didn’t do a good enough job since caster ended up off by more than 1 degree left to right.
    Stevie17 and bulalo[QUOTED] like this.
  8. Apr 16, 2023 at 8:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Some shops intentionally put a little "pull" to the right as a safety measure. Its done to prevent head on accidents due to drifting over the =centerline of a street if the driver isnt paying attention.
  9. Apr 16, 2023 at 8:36 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    This. https://www.myhonestmechanic.com/articles/new-tires-cause-front-end-of-car-to-pull.shtml. They diagnosed it when they move tires left to right and the pull went opposite. Is your tire duratrac? Mine is
  10. Apr 16, 2023 at 8:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It could also be tire pressure.
  11. Apr 16, 2023 at 8:42 AM
    bbougenot
    Basile
    Pressure on OEM tires match the numbers on the door sticker so I don’t think that’s it. Switching the front two tires seems like an easy enough experiment so I’ll give that a try. Thanks for the tips everyone!
  12. Apr 16, 2023 at 2:42 PM
    Blisterinthesun
    Blisterinthesun Well-Known Member
    2020 Tacoma SR access cab 4x4 V6
    Alu-cab canopy and rear jumpseat delete.
    Looks like a lots covered here. Sometimes in can be simple as rebalancing the wheels and check tire wear.
