Snorkel Install on 05+ Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by barlowrs, May 1, 2010.
  1. May 1, 2010 at 6:14 PM
    barlowrs
    barlowrs [OP] Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    Well after crossing the water crossing on the Mojave Road MULTIPLE times during a recovery operation, and seeing how DUSTY my air filter was after 3 days out in the Mojave, I figured it was high time to install my snorkel.
    Now as most probably know, there is no snorkel made for the 05 Tacoma, however, it has been discovered that it is possible to modify a snorkel for a 2.8L Helix Diesel.
    Parts List:
    Part# ARB SS135HFD
    3”-3” Rubber Flexible Coupler
    6” Length of 3” exhaust pipe (muffler shop scrap yard)
    First step was to get it in place. Unfortunately, since it is not made for an 05+ Tacoma, the template can be used for nothing more than getting the holes lined up with respect to each other, so to actually decided where the snorkel goes, it is just a lot of mocking it up, lining up the antenna spot, as well as the A-pillar mount, and hoping you got it. Once you think you got it, its time to cross the point of no return, and drill a BIG @$$ hole in the side fo your truck.
    Now, once the holes are all drilled, it is time to mock it up and drill the A-pillar holes in place.
    There are a few gaps, as the body lines are not the same as the helix, but they are not noticeable unless you REALLY get up close and look at it.
    Believe it or not, this was the easy parts….its now time to plumb it.
    Now there are many different methods to doing this. I chose to reuse my stock intake tubing bu cutting it off behind the big bulge. This allows me to use the stock flexible tubing.
    After a LOT of muscling the rubber elbow that came with the snorkel to get it to come out at a somewhat useable angle, I was able to connect the 6 in piece of muffler tubing and connect the two.
    Also note, there are two holes in the filter box that need to be sealed to make it watertight. Sorry I did not get more pics to help along, I was in a hurry to install it and didn’t get many.
    Anyway, here is the final product:
    Pirhett likes this.
  2. May 1, 2010 at 6:22 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    God damn! That looks great man...I wanna put one on my truck!
  3. May 1, 2010 at 6:29 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
  4. May 1, 2010 at 6:31 PM
    ColtsTRD
    Scott
    AZ
  5. May 1, 2010 at 6:32 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    WOW-that's impressive..looks like you put a lot of time into details and it definetely paid off.
    Thanks for sharing the pics!
    Azbackcountry
  6. May 1, 2010 at 6:33 PM
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
    I don't know how I feel about putting holes in a perfectly good truck, that took a lot of balls. Nice job!:)
  7. May 1, 2010 at 6:33 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    If you go to cruiser outfitters website they still the whole kit..minus the exhaust pipe for 355 bucks.
    [FONT=Arial,Helvetica][SIZE=-1]Toyota Tacoma (2005 - 2008) - $355.50[/SIZE][/FONT]
    [FONT=Arial,Helvetica][SIZE=-1]Retail $487.01[/SIZE][/FONT]
    [FONT=Arial,Helvetica][SIZE=-1](Fits all 05' & Newer 2nd Generation Tacoma's)[/SIZE][/FONT]
    [FONT=Arial,Helvetica][SIZE=-1]Part# ARB SS135HF/135HFD
    (See special install instructions here: 05+ Tacoma Snorkel Install)
    [/SIZE][/FONT]
  8. May 1, 2010 at 6:34 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    i literally gasped when i saw the hole.. i dont know if i could do it!
  9. May 1, 2010 at 6:34 PM
    barlowrs
    Robert
    So Cal
  10. May 1, 2010 at 7:10 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    looks damn good. i also like the idea of reusing the stock intake tubing instead of getting metal piping bent for it
  11. May 1, 2010 at 7:20 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Sweet! Looks nasty!
  12. May 1, 2010 at 7:26 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    That looks awesome!!! If only I could justify spending my money on something like that. I need tires more than anything. And with all the mods I see on here I have trouble saving for the tires! :eek:
  13. May 1, 2010 at 7:30 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Looks damn good man! Your truck is awesome as hell!
  14. May 1, 2010 at 9:37 PM
    ak_karl
    ak_karl Member
    karl
    alaska and washington
    o8 tacoma trd
    icon front, darkars and 5100 in the rear
    lets see some action pictures!!!!
  15. May 1, 2010 at 9:52 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    That shit is hott
  16. May 1, 2010 at 10:02 PM
    barlowrs
    Robert
    So Cal
  17. May 1, 2010 at 10:09 PM
    wolfeye
    wolfeye Well-Known Member
    I need a all pro plate bumper first!
  18. May 1, 2010 at 10:11 PM
    fsbrain03
    fsbrain03 Well-Known Member
    Your tuck is AWESOME! I'm just sayin...
  19. May 1, 2010 at 10:18 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Wow, nice truck! Love it!
  20. May 2, 2010 at 2:38 PM
    barlowrs
    Robert
    So Cal
    Thanks everyone, she is starting to grow up, but I have MUCH more plans for her..haha
