Snorkel Installation: 2nd Gen SS135MOD & 1st Gen SS170HF
Discussion in 'Performance and Tuning' started by misc, Feb 20, 2011.
  1. Jul 6, 2011 at 3:29 AM
    #441
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Only thing is the engine bay heating up the piping. I checked to see if I have leaks to where maybe hot air from the engine bay was getting sucked in and no. I have noticed on a hot day after running the truck the exhaust pipe piece is really hot. So that is why I was wondering if you had a way to measure it since you wrapped yours. It averages 12 degrees warmer but if it is cool outside it comes down to 6 degrees difference.
  2. Jul 6, 2011 at 7:20 AM
    #442
    misc
    misc [OP] Well-Known Member
    Ive never checked the temp of mine and I have no means to do so, but I am now curious. I would suggest you wrap yours as well. The temp difference isn't that bad if you consider all of the vehicles that still suck air from the engine bay.
  3. Jul 6, 2011 at 7:24 AM
    #443
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    Just raising your intake air temps...
    That's why I kept the stock stuff... :D
  4. Jul 6, 2011 at 7:29 AM
    #444
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    the 4 banger does not have anything other than the stock air hoses and connectors in the engine bay. all the connections where made in the wheel well. i'm still wondering if myself and tacovendor are the only ones that have snorkeled a 4 cylinder.
  5. Jul 6, 2011 at 7:31 AM
    #445
    misc
    I guess the slow crawling could raise it up. My air temp censor is back in my engine bay (lazy man's horn relocation) and my temp this weekend was up to 122*.
    :bananadead:
  6. Jul 6, 2011 at 7:31 AM
    #446
    Fire931
    VA
    00 4Runner
    Since when are you worried about hurting anything on your truck??
  7. Jul 6, 2011 at 7:38 AM
    #447
    misc
    Well you don't have any worries about engine temp since we didn't have to add in any heat conductive pipe :D
    No worries....unless your wheeling in Hell :D I would imagine it might not be the most efficient fuel burn, but it will help in the winter when the engine struggles to maintain operation temp :cool:
    This winter Ill be turning mine around if it's below 30* to see what happens.
  8. Jul 6, 2011 at 1:23 PM
    #448
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    i will very soon. how is it working anyways?
  9. Jul 6, 2011 at 6:36 PM
    #449
    Gramps
    Gramps
    07 TRD DC 4x4
    I drove to the airport this morning. The temp outside was 67 the whole drive. Once the engine was warm the intake temp stayed at 77. So 10 degrees difference. I am going to get some wrap to see if it cuts it down at all.
    If you think about it from a HS science perspective colliding molecules going down that pipe and colliding on the corners as it goes toward the engine bay would create heat as all colliding molecules do. So I could realistically see a 2 to 3 degree increase by the time it hits the MAF. So I think the exhaust pipe might be absorbing engine bay heat and increasing the temp. So we will see once it is wrapped.
    Considering you were getting air from inside your fender before with the stock intake I would be willing to bet that the temp was much higher before than it is now. But I don't know that for sure. Just have a hunch. :D
  10. Jul 7, 2011 at 4:54 AM
    #450
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    with mine, i've noticed as low as 3* difference, but it usually sits around 5-6* when driving. best i noticed w/ just the AFE drop in was 6*.
    btw, check your air filter more frequently now. i was changing my plugs this weekend and took off the air filter box and i had a whole dragonfly, several large bugs, and even a tree frog pushed to the backside of my air filter.
  11. Jul 7, 2011 at 5:28 AM
    #451
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    lol pm oswego he can help! :D
  12. Jul 7, 2011 at 5:38 AM
    #452
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    my engine sounds and runs ten times better since the snorkel has been on. the flowmaster exhaust i installed killed it before this either that or it was that stupid resonator thing. now it seems a little more eager to rev and it also took care of the popping noise i would get from the less restrictive exhaust when i roll off the gas.
    all in all i would say a nice exhaust and the snorkel is a great combo. i have a afe pro dry s drop in filter on order as well to see if that will further smooth shit out.
  13. Jul 7, 2011 at 8:04 PM
    #453
    Gramps
    Gramps
    07 TRD DC 4x4
    Holy crap an entire frog? Yeah noticed that this weekend when I cleaned it. Whole bugs in there.
  14. Jul 11, 2011 at 8:31 AM
    #454
    Lono
    Lono Member
    Aaron
    Salt Lake City
    2011 Taco
    ARB Front Bull Bar Bumper, Warn M8000 Winch, Hella 500 Front Lights, Bilstein front and rear, Leer 100XR Shell, ARB Roof Rack, Safari Snorkel
    I was told not to run a flowmaster exhaust (or any other performance exhaust) with a snorkel. Am I wrong with this info?
  15. Jul 11, 2011 at 8:32 AM
    #455
    Lono
    Lono Member
    Aaron
    Salt Lake City
    2011 Taco
  16. Jul 11, 2011 at 9:24 AM
    #456
    Lono
    Lono Member
    Aaron
    Salt Lake City
    2011 Taco
    What one would you do first, and what do you think about a magnaflow setup?
  17. Jul 11, 2011 at 9:26 AM
    #457
    The_Hodge
    SC
    dont buy the catback if you do. i bought the same SS muffler from the catback for $60 shipped off ebay and paid $100 to have it welded in and new pipe ran that dumped after the axle.
  18. Jul 11, 2011 at 11:22 AM
    #458
    Lono
    Lono Member
    Aaron
    Salt Lake City
    2011 Taco
    So you'd do the exhaust system before a snorkel?
    Doing this in baby steps.
  19. Jul 11, 2011 at 12:19 PM
    #459
    The_Hodge
    SC
    not saying i'd do one before the other, but i just wouldnt pay extra for a premade catback from anywhere.
  20. Jul 11, 2011 at 12:54 PM
    #460
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    I've been asked many times if I have ever actually crossed water that would enable the use of the snorkel, and each time I just give'em a big ol' smile and say, "no, I haven't finished getting her ready yet, waterproofing other parts of the truck that is".
    From what I have gathered from you guys, is that the door seals are not great at keeping water out, some components, either electrical or mechanical under the hood should/need to be water proofed in order for the snorkel to be fully capable. Not to mention the diff breather mod, which I have not done.
    So what else needs to be waterproofed?
