Snorkel or no snorkel?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fred d, Jul 17, 2018.
  1. Nov 1, 2018 at 3:00 PM
    #81
    eon_blue
    Azusa, CA
    Watched a buddy of mine nearly hydrolock his 2nd gen because of this...he cut the fender liners to fit 35's and didn't cover it up, we all went through a big puddle on one of the trails we did after a rain and he sucked up a bunch of water and stalled. I thought for sure he locked up the motor but luckily after we removed his air filter (which was soaking wet) and let the truck sit for a bit, it fired up after cranking for awhile. He bought a snorkel the next day lol.
    Running Board Man likes this.
  2. Mar 22, 2019 at 12:34 PM
    #82
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    At Red River Gorge :anonymous:
  3. Mar 22, 2019 at 12:51 PM
    #83
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
  4. Mar 22, 2019 at 12:54 PM
    #84
    chrispchicken9
    Does a filter not clean the air?
    Primary function imo is deep water crossings
    Even then I'm sure there's a lot more work getting truck capable of water crossings than attaching a plastic snorkel to your intake!
  5. Mar 22, 2019 at 1:29 PM
    #85
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    That's why the primary function of a snorkel is clean, cool air; not water.
    Arctic Taco likes this.
  6. Mar 28, 2019 at 10:30 PM
    #86
    penadam
    penadam Well-Known Member
    Denver
    2003 Double Cab Tacoma TRD
    The main reason you get cleaner air is your intake is no longer in the wheel well. The tire kicks up a ton of dust which will clog up your filter faster. Additionally, the higher intake location prevents larger particles from entering the intake; they are too large to make it up that high.
    As for water crossings, I did one that was deeper than expected, and I ended up with water/mud halfway up my air filter. That and the dust reduction made it a no brainer for me with how cheap the hilux snorkel is.
  7. Mar 28, 2019 at 11:43 PM
    #87
    eon_blue
    Azusa, CA
    Snorkels weren't designed for that reason, you said it yourself - there's a lot more that goes into making a truck capable of water crossings. Snorkels pull cleaner air from higher above the ground rather than all the dirt and debris that the stock intake pulls from the wheel well.
  8. Mar 29, 2019 at 4:25 PM
    #88
    chrispchicken9
    just seems like the term "snorkel" indicates there is water
  9. Mar 29, 2019 at 8:03 PM
    #89
    TX Bat
    TX Bat Enabler
    Keith
    North Texas
    2019 TRD Pro BLACK
    That's why Toyota calls it the "Desert Air Intake".
  10. Mar 29, 2019 at 8:06 PM
    #90
    eon_blue
    Azusa, CA
    That was a name given to them after the fact I believe and it stuck. They weren't originally designed for that purpose but if you build the truck to cross deep water regularly then a snorkel is a must. But even if you don't do water crossings, a snorkel is a great tool for pulling cleaner and colder air for the engine.
    I monitor my air intake temps regularly since I'm supercharged and since putting the snorkel on I see a good 10° difference in lower intake temps. Every little bit helps especially on a 1st gen since our superchargers aren't intercooled. Intake temps can skyrocket especially in the summer.
  11. Mar 25, 2020 at 8:26 PM
    #91
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4, 2011 Camry LE
    Overbuilt daily driver
    Ayyyy necropost!
    Does anyone have input about snorkel performance during extremely heavy rainfall, say a hurricane or something similar? I managed to stall my old F150 during Matthew a few years back, and that was driving on non-flooded highway.
  12. Mar 25, 2020 at 9:22 PM
    #92
    eon_blue
    Azusa, CA
    I don't live where there are hurricanes but in the last couple years I have taken my snorkel through some torrential downpours. At most I've seen a tiny bit of water make it's way to the filter but nothing that would go past it. And that's only happened during a huge storm when I was cruising on the highway for miles.
    The snorkel is designed to evacuate water through the drain slots built into it under the snorkel head and it works well, I don't think it's something to need to worry about. ARB only recommends turning the head around during heavy snowfall so that it doesn't accumulate on the face of the snorkel and block the airflow. Otherwise there's no need to worry about turning it
  13. Mar 25, 2020 at 10:23 PM
    #93
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    You gotta understand that if you just throw a snorkel on it doesnt mean you can just submarine deep crazy theres more that goes into it, I have one and tbh its just for looks let be honest, but it was a pita to put on, heres a tip for anyone trying to put one on, when you attach the oem tune to the snorkel tube spray some wd40 for it can just slip right in, also the drawing they give to make the holes just make them a tad bit bigger and if you want put some sealant on the snorkel nase where it touches to hole to seal good
  14. Mar 25, 2020 at 10:47 PM
    #94
    ardrummer292
    Austin
    ESVA
    Thanks for the feedback. Ya know, I wouldn't have thought that a hurricane could make a vehicle stall out without some extenuating circumstances (like trying to ford a flooded street). Matthew proved me wrong, hence my line of questioning.
    Oh I know, with breather tube extensions/relocations for your tranny and differential and whatnot. Since my application would be solely for ensuring engine function during extreme rainfall coupled with extreme wind, I think I can probably do without the extra mods.
    I'll look into this a bit further. I know it's probably excessive installing a snorkel for this application, but I can't think of another fix. Plus, there's no kill like overkill.
  15. Mar 26, 2020 at 6:45 AM
    #95
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    If that is the only reason you would be installing a snorkel, I think you would be wasting your money. I think the stock intake would be as good, maybe even better, for that specific scenario than a snorkel.
  16. Mar 26, 2020 at 6:48 AM
    #96
    Gyrkin
    Wyoming
    It is truley is just for looks why not skip cutting a hole through your fender, and just surface mount it?
    DK117 likes this.
  17. Mar 26, 2020 at 6:55 AM
    #97
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    If your gonna have it might as well have it functional.
  18. Mar 26, 2020 at 9:08 AM
    #98
    ardrummer292
    Austin
    ESVA
    It's entirely possible that I'm misdiagnosing the problem my old F150 experienced. It seems that it could have been due to a sensor getting wet rather than water intrusion through my air intake. This means the addition of a snorkel will functionally do nothing for me.
    Does anyone else have input?
  19. Apr 28, 2020 at 12:39 PM
    #99
    #NEVERGIVEUP
    #NEVERGIVEUP Well-Known Member
    California
    2017 Quicksand DCSB TRD OR
    TBD
    Who managed the group buy the last time?
  20. Apr 28, 2020 at 2:17 PM
    #100
    #NEVERGIVEUP
    California
    TBD
    I see. Would like to see another group buy for this soon.
